Page 1 of 4 1234 LastLast
Results 1 to 20 of 80
Thread: Hayward AQR15 Aqua Rite
    Nov 2015
    Ok ok
    823
    I want to convert to a saltwater generator, and pretty much settled on the Hayward AQR15. My pool is probably around 16k gallons. Here is my question, currently my pool filtration pump is run from mechanical timers that are located on the side of my house probably 100 feet from my pump and filter. Does this this SWG run on 110? My pump is on 220. If I understand correctly, this unit needs to run at the same time the pump is running, is there a way to wire it into my pump when it turns on and also shuts down with my pump as well? I definitely will hire an electrician, but was wondering if anybody could explain in simple terms to me how this might work. I understand the plumbing, it's the power that is confusing me.
    ~14K gallon - AquaRite AQR15 SWG - pool Newly plastered on April 9 2016
    TF100 kit - STA-RITE SYSTEM3 Modular Media Filtration - Model S8M150
    Pool water supply from on site water well = CH of ~350 and TA of ~350
    Doheny's Discovery Automatic Robotic Cleaner/Pentair Model 011018 VS Pump
    Sundance Altamar Hot tub separate from pool / central Oklahoma
    Nov 2015
    Ok ok
    823
    Re: Hayward AQR15 Aqua Rite
    I just wanted to say that while reading another thread there is a very similar situation as mine. from reading there it sounds like it can be wired into 220, and I am guessing it would turn on and off with my pump that is controlled by the timers. That said I would still like to have my own thread with my own situation. Thank you.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Yes, the SWG runs on 220v and should be wired to the same timer as the pump.
    Nov 2015
    Ok ok
    823
    Thanks pooldv. How long after new plaster should I wait before adding salt and SWG?
    DFW, TX
    24,497
    The safe answer is 30 days. If you are OK with using bleach for 30 days then you might as well play it safe and wait. My PB added salt and turned on the SWG the day after it was full. 4 years later everything is fine.
    Nov 2015
    Ok ok
    823
    If I were to get the SWG and plumb it in, it's OK sitting there with no power, correct? Or would water flowing through it while it's not generating be detrimental? I am just thinking about getting it, getting it plumbed in, and then waiting a month or so to wire it up.
    Jun 2015
    Charlotte, NC.
    82
    No problem with having it sitting in place without wiring it up - that's exactly what happens all winter or when the cell is resting even during normal use.
    - Matrioux
    2007 18K pebble IG pool - Wincor Pool Systems automation & SWG (under development) - DE Jandy DEL60 Filter - Jandy 1HP Pump - TF-100 Test Kit
    Jun 2011
    Long Beach, CA
    2,788
    It's alright to wire it in, just turn the switch to the off position on the AquaRite panel.
    Nov 2015
    Ok ok
    823
    Thx
    Nov 2015
    Ok ok
    823
    How long of a run, in inches, do I need to set the cell? Also does the sensor have to go in the same length or can it be in a different spot other than the straight area the cell is in? I am trying to predetermine the location before I order this. Thx again.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    There is no requirement for a straight run before or after the cell, but the flow sensor requires 12 inches of straight pipe before it. If the cell is before the flow sensor it can count as part of that. Also the cell and flow switch should be the last thing in the plumbing before the water returns to the pool.
    chiefwej
    Nov 2015
    Ok ok
    823
    Thanks Chiefwej, just so I'm clear here's a picture of what I got going .... is exactly 14 inches inside to inside of the elbow connections. You can see on the second picture the entire discharge pipe from my filter. Is that 14 inches enough room to fit everything with fittings? The connection below it is my booster pump getting fluid from the pump discharge.
    Saturn94's Avatar
    Mar 2015
    Virginia
    500
    My T15 cell with unions is 16.5" long. That's not including space for the flow sensor.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    I actually think it is 16" for the cell and couplings, but in any event you are going to have to do some plumbing. There are several ways to do it. You just need a space for the cell (it can be mounted vertically as well as horizontal and can be right before or after a 90) and a spot for the flow switch that is preceded by 12" of either straight pipe or the cell.
    chiefwej
    Nov 2015
    Ok ok
    823
    Thank you for that information.
    Nov 2015
    Ok ok
    823
    If possible, could somebody snap a picture of one installed?
    Sep 2013
    Charleston, SC
    537
    Quote Originally Posted by Lykly View Post
    Mine is installed vertically and I'll take a pic of mine tonight and post.
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    chiefwej
    Sep 2013
    Charleston, SC
    537
    Here is mine. It is hard to get a clear shot as there is a well pump in front of it. Sorry for the leaves as we haven't cleaned up from the winter yet.IMG_1401.jpg
  20. Back To Top    #20
    Nov 2015
    Ok ok
    823
    Thanks Otter. Chief, your picture link will not work, at least not for me?
