Results 1 to 9 of 9
Thread: Strange stuff on bottom of pool <pics>
    Apr 2009
    Sarasota Florida
    143
    As far as I can tell i have all my chemicals right were they need to be.
    FC-9
    CC-0
    TC-9
    TA-100
    CH-somewhere between 260(fill water hardness) and 400.waiting for the mixer to come to get an exact one
    CYA-60-70
    PH-7.5
    The swirly streaks and light color dots have been there since i bought the house 7 years ago. Pool company told me it was metals and they actually did a treatment last year which helped alot. My real concern is the 2 black dots that can be clearly seen. They are perfectly round and seem to be smooth to the bottom of the pool. I swam down the other day and felt them. Nor do they rub away with my finger. Any idea what they might be?
    Thanks
    Kidney shaped ~ 10000 gallon Ig Plaster pool with pool cage. 120sf Cartridge filter. Pentair WhisperFlo WFDS-26, 230 Volt, 7.8/3.0 Amp, 1-1/2 Horsepower 2 speed pump, Solar panels on the roof. Heliotrope HelioMatic 4000D solar controller.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Strange stuff on bottom of pool <pics>
    Hey, how old is the plaster?
    Did you drop a penny down there (sorry, Mike, I can't tell what size that dot is )
    Did you test the spot.......for organic or metals stain?
    ....and the pool company did what treatment to make things better?
    btw, I am absolutely jealous of your screen cage
    You're done SLAMing when:
    Butterfly's Avatar
    South Carolina
    10,045
    Forgot to add, your #'s look great, too!
    Apr 2009
    Sarasota Florida
    143
    Quote Originally Posted by Butterfly
    lol no it is not a penny. Its about the size of a pencil eraser or a bit larger. There are 2-3 spots like that. Plaster is considerably old. This winter it will be redone. There are spots on the water line where it has flaked off.
    I haven't tested for either as i need to read up on how. The pool company last year took my chlorine to 0, put some chemical in that caused the streaks to lift and then get filtered out. It was some type of metal treatment, not sure the specific name though. The dots are something new i think, not something that they treated for.
    Ya i thought it was pretty cool that i could get that good of a picture of the bottom of my pool and even show the reflection of the cage.
    Butterfly's Avatar
    South Carolina
    10,045
    Mike, sounds like they (pool co.) did the ascorbic acid treatment to lift the stains. Meaning metals. (You can read about this treatment in Pool School and see if it sounds to you like what they did.)
    Well, if the plaster is going to be redone this winter, you will certainally want to explore what caused the stains so that they can be avoided in the future!
    Have you had your fill water tested? I'd start there.
    It could also be something the pool co. put into your pool ...or maybe you
    Others will chime in later w/ideas.
    Apr 2009
    Sarasota Florida
    143
    Not really worried about the streaking, mostly the black dot, well the several black dots. The streaking I will look into when I get closer to refinishing the pool
    Apr 2009
    Sarasota Florida
    143
    Ok, so i left the 2 spots that were bothering me alone and now i have 3 more on the opposite side of the deep end. I put a vitamin C tab on one last night and will see if it did anything to it when i get home. If no change what is my next step? Its the round black dot in picture 1. I have 3 in close proximity now in the deep end.
    Thanks
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    If it didn't change it at all, try a trichlor puck on the spot too.
    Apr 2009
    Sarasota Florida
    143
    Quote Originally Posted by frustratedpoolmom
    vitamin c tab did nothing. i was just reading your other thread where you suggested she do that. I think i have some tabs in the garage. They have been there forever. Do they go bad? Ill try that next.
