Results 1 to 17 of 17
Thread: Just how bad is my plaster ?
    Jan 2016
    PLEASANTON, CA
    7
    Yet another new pool owner here. We bought this house with a pool just before winter. After spending hours and hours on this site, I said good-bye to the pool guy, purchased a TF-100 test kit and just found out that CYA level is around 160 (half tap water method). And then decided to drain the pool.
    However once the water level started to go down, I am seeing all the cracks that weren't obvious with the water in. Now I am wondering how bad these cracks are ? How long do I have before I will need a full re-plaster ? Pictures follow.
    WP_20160406_16_47_21_Pro.jpgWP_20160406_16_47_52_Pro.jpgWP_20160406_16_48_08_Pro.jpgWP_20160406_16_49_20_Pro.jpgWP_20160406_16_46_57_Pro.jpg
    14,000 Gallon Gunite Pool, Hayward 48 sq. ft. DE Filter, Hayward single speed pump, Spa
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,602
    Re: Just how bad is my plaster ?
    That looks like plain jane concrete to me.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,492
    Welcome to TFP! Congrats on the new pool!
    Wow, that doesn't look good for the home team! If it holds water and doesn't leak you can live with it as long as you can/want to. But, once it starts to leak then you'll have to pull the trigger on a new plaster job. I can't see trying to repair that to fix any leaks.
    Good job punting the pool guy and getting a great test kit.
    Thanks for supporting the site, that supporter badge looks good over there!
    Jan 2016
    PLEASANTON, CA
    7
    Thanks for the advice. It does not seem to be leaking so far. I guess I will refill it for now and start saving up for a re-plaster.
    And after all the help I got from the site it would be a crime to not support the site.
    Jul 2011
    Arizona & California
    803
    As pooldv stated, you should re-fill the pool. Leaving it dry will cause further cracking. The cracking has nothing to do with the water balance.
    It appears that the plaster is losing it's bond to the substrate beneath. But the plaster may remain in place and not fall off the walls as along as it remains filled with water.
    If it is not losing water, it is fine, and re-plastering can be put off until you are ready.
    Jan 2016
    PLEASANTON, CA
    7
    Yup, those photos were taken while the submersible pump was doing its thing slowly. I replaced 80% of the water and started to work on stabilizing the chemistry. I am all excited to use the pool next week, confidently.
    I wish I had more reason to engage with this wonderful community but some 98% of the stuff I need to know is already covered in previous posts
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,321
    Nice pool! Cool design.
    Dolphin E10 Cleaning Robot.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,505
    Quote Originally Posted by dsprint View Post
    HA! We have some engagement you CAN do! Start off by doing some reading in the different forums. Try the algae prevention forum. As you read you will learn. Jump over to the "Under const" forum and do some reading. You can cheer and cry with people over their builds. We also have the "coffee spot" where you can chit, chat..........oh don't forget the cooking area--------yummmmmmm.
    As you learn jump in and answer as you can. The more you read, the more you will learn, the more you learn, the more you can help!
    I started here learning how to test my water with my test kit BEFORE I even ordered my pool! I wanted to make sure I COULD really do it! Look at me now-queen of the "under constr" forum because I LOVE to help people spend their money! LOL
    I look forward to seeing you around the forums!
    Kim
    DFW, TX
    24,492
    Alright! Here's to a great summer!
    Hang out, learn some stuff and help some folks if you can.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Hey, welcome to TFP, and thank you for your support.
    If it isn't leaking, that's great, but sooner the better. It's a really nice pool, and with some minimal TLC and know how, it won't look this way again. It worthy of a nice new finish and a soda blast to clean up the water line. It'll be really beautiful once re-done.
    Essential Links:
    Aug 2014
    Northern IL
    4,615
    Trust onBalance!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    My suggestion for sooner is purely for enjoyment factor. It's such a nice looking pool. Saving up for a fine finish however will reap very nice rewards.
    Essential Links:
    Jan 2016
    PLEASANTON, CA
    7
    I need to figure out how to receive email notifications when someone posts here.
    Thanks kimkats for showing me around.
    Jul 2012
    Tallahassee, FL
    30,505
    Try this for email notifs...
    -setting-upper right
    -general settings-middle left
    -Default Thread Subscription Mode
    -pick the one you want
    Let me know if this works for you.
    Kim
    Jan 2016
    PLEASANTON, CA
    7
    I just did that. Looks like that will work only for threads I start in the future. I manually subscribed to this one, for now. All well.
    Jul 2012
    Tallahassee, FL
    30,505
    It should also work on any threads you comment on as well. There is also a link called "thread tools" just above the blue/gray line at the top. It has a place you can click to subscribe to a thread you emails on.
    Kim
    Jan 2016
    PLEASANTON, CA
    7
    Yay, its all working now.
