Results 1 to 7 of 7
Thread: Pyrex triton minimax heater problem
    I've been researching this and thought it could be either of these things but now not sure...1 pressure switch bad and 2 power board bad...but I don't have any led lights including power green or lit...I have a Jandy aqua link system but haven't opened up the box yet..thinking now maybe relay or connection is bad to the heater? Anyone have any ideas?
    built 4/08/2000 16 x32 460 Sq FT Pool 16,000 gallons 3.5 ft 5 ft 3.5 ft sport pool
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Pyrex triton minimax heater problem
    Maybe these will help get you going
    Purex Triton Minimax Plus Service Manual
    Thanks Ive been watching that video...I tested my power yesterday and I don't have any lights on my led board.....it looks like I have power into the transformer but nothing out of it...so I ordered this
    Amazon.com: Pentair 471360 Dual Voltage Transformer With Circuit Breaker Replacement for Pool And Spa Heaters: Patio, Lawn Garden
    any trick to installing this?
    I just replaced transformer so now getting the green power light but no other lights? Any ideas?
    Is one of the "trays" just gone a victim of rust ? There is a bar/tray running across the bottom on the back side but only a pile of rust on the front..is that one that collapsed? And is that needed?
    I'm getting a tstat light along with power light...does that mean I need to replace the tstat?
