Thread: New to BBB
    Apr 2016
    Houston, TX
    23
    New to BBB
    Hi all,
    Brand new to the forum and would like to ask a quick question. My pool is roughly 15000 gallons on chlorine no SWG. On the BBB method what and how often should I check my pool water? I am using a Taylor K2600 testing kit from Leslies.
    Thank you
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: New to BBB
    Jun 2014
    15,153
    Re: New to BBB
    Welcome! Great to have you with us.
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    242
    Re: New to BBB
    Until I learned the character of my pool I tested everyday. Now, I test FC every other day and Ph and TA twice a week. I don't normally check Ch or CYA until water is added.
    14.3k, 3 1/2-5 1/2, IG, Pebble Wet Edge Northshore Tahoe, Jandy 4 cartridge, Jandy 2hp variable, Pentair 320 inline chlorinator fed by a Stenner, Polaris 280, K-2006 test kit, Built 9/13
    Fill water: TA=90, PH=70, CH=90
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: New to BBB
    Welcome to TFP!
    Please add your pool info to your signature so that we can better help you. More here, Pool School - Read This Before You Post
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: New to BBB
    Welcome, have fun and check out some stuff in pool school
