Results 1 to 8 of 8
Thread: trying to decide between ladder or stairs in deep end
    Apr 2016
    Ontario
    3
    Hello everyone! I'm new to the forum and hoping for your help. We are in final stages of selecting pool size/shape/accessories.
    We are likely going with Lagoon style from Latham Pool Products, 20x40 size which is quite large, 8' in deep end. We have a lot of parties and have kids ages 5 & 7.
    We will have 8' roman curve steps in shallow end and were thinking of having another set of same in deep end, along with a diving board.
    Idea is that people like to hang out on steps, plus we like the look of steps over a ladder.
    One concern is whether stairs will make it easier or more difficult to get out of the pool in the deep end? I've never tried myself. Not sure which is more functional?
    Any thoughts you have would be greatly appreciated!
    From Brantford, Ontario, Canada. Have a 20x40 inground vinyl lined freeform pool.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: trying to decide between ladder or stairs in deep end
    Welcome to TFP!
    You may want to check codes. Ladders may be required.
    It would seem to me you'd have to crawl out of the stairs in the deep end which would be kind of awkward. Also, stairs tend to collect debris, so you'll want a return in each set of stairs. I think I'd probably consider a tanning ledge or seat rather than the second set of stairs.
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    We have a bench type seat with 1 step in our deep end.
    Helpful Links: Pool Chemistry 101 - Recommended Levels - Recommended Chemicals - FC/CYA Chart - SLAM Instructions - Pool Math
    Test Kits:
    TF-100 - Taylor K2006 - SpeedStir Upgrade - Taylor K-1766 Salt Test
    My Pool:
    28k IG built May 2015 - Autopilot SWG - Pentair VS Pump/DE Filter/Heat Pump
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Most folks nowadays are using swimouts, aka benches, to get out of the deep end. They are also nice for kids to hang out on and adults to sit on and sip tasty beverages!
    Apr 2016
    Ontario
    3
    pinguy do you like the bench seat with step in the deep end? do you find it awkward to get out? thank you!
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    242
    I'm 56 and have no problem exiting from our bench.
    14.3k, 3 1/2-5 1/2, IG, Pebble Wet Edge Northshore Tahoe, Jandy 4 cartridge, Jandy 2hp variable, Pentair 320 inline chlorinator fed by a Stenner, Polaris 280, K-2006 test kit, Built 9/13
    Fill water: TA=90, PH=70, CH=90
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,274
    I have a swim out on my deep end and it is easy to get out and I don't have a step. Great place to sit in the water and my dog can use it to get out, too.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Quote Originally Posted by Harleysally View Post
    Yea we love it. Very easy to get in and out since it has a step, and its great to sit on with a drink. I would take a picture but our cover is on.
    Test Kits:
    My Pool:
