Results 1 to 7 of 7
Thread: Do any chemicals "settle" in uncirculated water?
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    I just took a water sample from our closed pool to calculate how much salt/CYA I would need for opening. We had a lot of precipitation in eastern PA this winter (water is up to coping), so I was expecting a good amount of dilution. However, the CH drop was more significant that I would have thought. It was at 475ppm at closing, and was at 75ppm from the sample I took. Pool math says I would have needed to replace 85% to see a 400ppm decrease.
    Do any chemicals like CH "settle" to the deeper water of an uncirculated pool? Are any of the tests not accurate in cold water?
    Helpful Links: Pool Chemistry 101 - Recommended Levels - Recommended Chemicals - FC/CYA Chart - SLAM Instructions - Pool Math
    Test Kits:
    TF-100 - Taylor K2006 - SpeedStir Upgrade - Taylor K-1766 Salt Test
    My Pool:
    28k IG built May 2015 - Autopilot SWG - Pentair VS Pump/DE Filter/Heat Pump
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    Re: Do any chemicals "settle" in uncirculated water?
    I don't have any specific scientific knowledge, but the general consensus is that the water needs to circulate for 30 minutes before you take a sample. It is possible that the melted snow/rain water is sitting on top... I'm sure it is compounded with any freezing/thawing action happening during the winter.
    I would expect you to see a slight drop in CH if you lowered your water at closing, but nothing close to those results.
    Did you store your testing reagents inside and way from the sun?
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,014
    If the pump isn't working, then yes, you have stratification. It's not unlike pouring a layered cocktail
    Stir up one of those drinks and you'll have some shade of brown...
    Get the pump running and brush the perimeter of the pool before you test again.
    The CYA test is sensitive to temperature. Leave the sample water inside on a sunny windowsill and get it above 70F before you measure it out and start mixing.
    38,303
    Agreed, you need to circulate before testing because the new water could certainly be sitting on top.
    30,421
    Great Graphics, R320!
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    LOL I was imagining it as more oil and water, but this looks much tastier.
    Thanks!
    Test Kits:
    My Pool:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    CYA needs to be tested at room-ish temperature.
