Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: CYA about 200, need help on draining pool
    Apr 2016
    Las Vegas, NV
    48
    Hi, my CYA is about 200 based on the black dot test that I did and I want to drain my pool asap. Yes, I got "pool stored" by LPS and bought a bunch of 3" tabs, but I got them at Sam's club because they were much cheaper
    That was 3 months ago, and I've been testing levels myself
    I understand I shouldn't drain the entire pool, and to leave at least a foot in the shallow end. By my calculations, I need to drain 80% of the pool
    I did see a blue hose coming out of a yard down the street to where I live, so I suppose that's what I have to do somehow
    Attached is a pic of the pipes connected to my pool pump with the labels 'main drain', 'cleaner' and 'skimmer'.. .not sure what that all means and how to change the function
    Is it best I just hire someone to drain the pool?
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,511
    Re: CYA about 200, need help on draining pool
    Gex,
    We really need a picture of your filter and any valves that might be attached. The type of valve/filter you have will make difference on what you will need to do.
    Jun 2014
    15,152
    Gex, welcome to TFP! As Jim noted, a pic of your filter will clue us in on how to best drain your water. Also, now would be a good time to please add your pool info to your signature by going to the top of the TFP web page (just under the Pool School button) and select "SETTINGS". On the next page look to the left for a menu bar that says, “MY SETTINGS” and go to "EDIT SIGNATURE" to enter your pool and equipment info there. It will help us later. This link may also help you: Pool School - Read This BEFORE You Post. Nice to have you join us.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Welcome, We will get you going
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Welcome to TFP!
    Apr 2016
    Las Vegas, NV
    48
    Quote Originally Posted by Jimrahbe View Post
    Gex,
    pictures of filter attached. i have an aqua pro, apf200pro
    38,295
    That looks like a cartridge filter which does not have a waste/backwash line. So you would either have to take the lid off the filter and run the pump suction from only the floor and flood your backyard, or you will need to buy/rent a submersible pump with hose and pump out the water to a more desired location.
    Apr 2016
    Las Vegas, NV
    48
    another pic of filter and pump
    thanks, i think i will just hire someone to do that, since i don't know exactly what tools i need to rent and the submersible pump sounds expensive
    i'm guessing a pool guy would charge me $100 for a service like that?
    in-ground pool approx 8-10,000 gallons. plaster i think.
    38,295
    You can rent a pump with all the hose you want from Home Depot for around $40 I think. Or for a similar price, buy a smaller one from Harbor Freight, it will take a lot longer to drain though.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,525
    This IS something you can do yourself.......these guys will get you going.
    Kim
    Feb 2015
    Chandler AZ
    933
    The following may work....
    Turn all suction to main drain, then hook a hose to the spigot above the pump and run to selected drain location. Turn pump on and open spigot. Will take a long time that way too - and will need to be monitored to prevent pump running dry.
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    Chris19D's Avatar
    Jul 2015
    Cypress, Texas
    89
    I'd do as jbizzle mentioned and buy or rent an electric submersible pump and pump it to a safe location. Or do a combo submersible / the instructions proavia mentioned in the post above.
    ~Chris - 20,000 gallons free-form gunite / Pebbletec, Aquapure 1400 SWG, 2 HP Jandy VS Main Pool Pump, 2 HP Jandy Water feature Pump, 580 Jandy cartridge filter, Dolphin M500, TF-100 w/Speedstir.
    Apr 2016
    Las Vegas, NV
    48
    any specific submersible pump?
    i see a 3/4 HP stainless steel on harbor freight for $60
    and a 1/3 HP thermoplastic on amazon for $53, that can work with a 1-1/4" trash hose (costs as much as the pump)
    i figure i should buy one since i can reuse it as often as needed
    Jul 2013
    Fletcher, OK
    3,353
    The 3/4 hp from harbor freight will do you just fine for as much as you will need it
    Dec 2015
    Chino/CA
    203
    Correct me if Im wrong, but as proavia mentioned earlier, you can drain your pool from this pipe circled without renting or buying anything:
    You could even remove the spigot to allow a higher water flow!!!!
    Chris B.
    New house w/ 28 y/o I.G. 15k gal. pool/spa, Plaster, Hayward DE-480S Micro Clear Filter, Pentair Whisperflo wfe-4, 1HP (Main Pump), Hayward SP2815x20 (Pump for spa jets), Versa Pool Heater, Hayward Pool Vac Ultra, TF-100 Kit
    38,295
    That is true, since they can isolate the floor drain. If you stop the pump after draining some, you might lose prime.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,008
    Quote Originally Posted by bakerboy View Post
    Indeed. My thought is a quick trip to Lowes or Home Depot for a larger fitting and a backwash hose.
    Shop Aqua EZ Hose Adapter at Lowes.com
    Shop Aqua EZ Hose at Lowes.com
    Sep 2015
    Orlando, FL
    33
    Why not just put a hose or 2 on the pool and siphon it out? Easy and cheap.
    16k gal, IG, marcite, 3HP VSP Ecostar, 2HP Booster 2speed, 200 sqft cartridge, SWG, Caretaker IFC, Omnilogic, Solar, Taylor K2006, Born 3/16
    38,295
    Quote Originally Posted by XSurfX View Post
    Great if you can. But, there is not typically land that is feet below water level near the pool to allow that to work for in ground pools.
  20. Back To Top    #20
    Sep 2015
    Orlando, FL
    33
    I ghettovaccumed some sand yesterday, suction end was 7' below waste end. Water level-->bucket was maybe 12" difference.
    My hose defies gravity. And can someone please make a pockethose (the shrinking kind) that doesn't self destruct?
    Gex, did you correct your CYA?
