Thread: Pool brush recommendation
    May 2015
    Cartersville, GA
    14
    Looking for a recommendation of a brand of steel scrub brush for my pool. The one I have, just plain old steel brush from Wal-Mart, Home-Depot, etc. 2nd season using it... When I use it, the bristles come out and are left all over the pool to stick feet or hands when emptying the Polaris bag.
    Thanks
    20k gal, Plaster/Pebble, Pentair Tagelus Sand filter TA100D w/ TM-22 multiport valve;
    Intelliflo Variable Speed 3hp pump; Aqua Rite 25k SWG, Polaris 280 Sweep Vac
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Pool brush recommendation
    I have this one but no metal bristles, they work great and get great reviews.. This one has the metal in it...
    Amazon.com : SweepEase SS/POLY BLEND Brush AquaDynamic Pool Brush, 18-Inch : Patio, Lawn Garden
    tcat's Avatar
    May 2012
    Austin, TX
    731
    I have that same one. Excellent.
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    492
    i use the whale tail brush
    the spoiler adds downforce brushing much harder
    when you pull back the spoiler folds over making it easy to pull back
    Amazon.com : The Wall Whale Classic Swimming Pool Brush : Patio, Lawn Garden
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    I use this one, Paradise 18 Turbo Brush Swimming Pool Brush | PTB100 and it works great. I wanted a little extra pressure without a full on whale tail.
    Jul 2015
    Central Valley CA
    1,109
    +1 on the Wall Wale never going back to a normal brush, I tried a normal one for a total of 2 weeks and could not believe the difference when I got the wale. The brush they sell with the whale tail is nice and the tail can also be installed on many other brush heads when the brush wears out.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
