Thread: leaking in ground tile pool
    May 2014
    hawaii
    4
    my in ground tile pool is leaking real bad. is there some kind of thick roll on or spray on urethane coating I can use? I once found a 2 layer coating, 1st layer was the thick sealer and the 2nd was a quarts looking layer, it was a urethane of some sort. I cant find it anymore? or is there anything else I can use.
    thank you!
    Apr 2013
    Sacramento, CA
    2,769
    Re: leaking in ground tile pool
    Welcome to TFP!!!
    Is it completely tiled?
    Can we get a picture?
    There are several products that can be rolled on. They won't look nice but they will control your leak for a while over a tiled surface. Are you talking about a clear coating?
    I would recommend determining the source and cause of the leak and repairing that. This is a more expensive solution but it should last longer and look better.
    May 2014
    hawaii
    4
    Quote Originally Posted by gwegan View Post
    Welcome to TFP!!!
    sorry for the late reply, the notification was sent to my junk folder.
    Yes, the entire pool is tiled. I will get a photo. finding the leak would be to hard and being in a earthquake prone area, I need something that can flex. I was looking into products like LINEX or something of that sort. The system I found previously but cannot find again was a 2 part, first was a thick seal coat and then a top coat that had a "quartz" look. I liked it but could not find the product again.
    Thanks!
    Oh, and I don't care if its clear, I don't need to see my tile anymore.
    Thanks.
