Thread: Concrete and Saltwater Pool
    Apr 2016
    Grimsby Ontario
    22
    I sure this have been brought up before - I was reading on line that you cannot have concrete deck and a Saltwater Pool.. the pool water will destroy the concrete in time...But if that was the case wouldn't the sidewalks and roads be just dust and rubble... Is there an issue with pool ladders and pumps and stuff... We used to have an Intex pool with a SWG and it was great.. We moved and we have an old 1960's concrete pool with vinyl liner....I don't want to make a costly mistake switching to saltwater...
    Tim
    ____________________________________________________________ ____________________________________________________________ ____________
    14 x 28 x 5 1/2 feet - 16000 gallons - IG (1960's concrete) Vinyl Liner, Sand Filter (Sand Master SM2306T), 1 hp Purex Challenger? (Faded label), Municipal Water.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: Concrete and Saltwater Pool
    Completely false. Concrete is one of the most durable surfaces around saltwater pools.
    38,475
    The salt levels in a pool are 10x lower than the ocean (plenty of concrete around the ocean). And the salt levels used on roads is even higher.
    Apr 2013
    Sacramento, CA
    2,769
    I'm not saying that saltwater damage to concrete or stone is false, but it is certainly overblown. we don't see that many issues on here about saltwater damage. And as can be seen looking all around saltwater and concrete get along just fine. Or are all those bridges in Miami falling down?
    38,475
    The most likely to have a problem with the salt around a pool (natural stone more than concrete) are in areas where the climate is very dry and there is little rain. So the salt from splash out can kind of build up in nooks and crannies and cause problems. If you get fairly regular rain, then that washes all the salt away. Or you can spray everything down yourself on occasion.
    Apr 2016
    Grimsby Ontario
    22
    thanks - the concerns didn't seem to be right...
    Tim
