Results 1 to 13 of 13
Thread: Solar cover = increase in algae?
    Apr 2015
    Bay Area, California
    19
    Anyone notice this after covering the pool there is a dramatic increase in algae. Looks brown on the walls. Cover for about two or three days at a time.
    - 25,000 gallons in ground fiberglass pool
    - Pentair Clean and Clear Cartridge Filter
    - Pentair VS Inteliflo Pump, Pentair SolarTouch with Solar Panels - 8 hrs run time.
    - Poolmaster 22260 5-Way Test Kit
    - Polaris 380 with Hayward Booster Pump
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Solar cover = increase in algae?
    Quote Originally Posted by John55 View Post
    Nope. If yoiu maintain the proper FC/CYA ratio you should not get algae..
    You need to follow the SLAM Process to eliminate the algae.
    Back in May you said you were getting a better test kit. Did you get one or are you still using the Poolmaster 22260 5-Way Test Kit?
    Support the site
    Donldson's Avatar
    NW Ohio
    2,892
    Yeah, what Tim said ^ If you are getting any algae at all then there is something wrong with your water chemistry, cover or no cover.
    From my HTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Apr 2010
    Buckeye, AZ 85326
    619
    I've had my cover on for a month or so now with zero issues.
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Are you taking it off to brush?
    Apr 2015
    19
    Copy that. I brush once a week.
    I did get a kit but now it's old. Still got algae only when covering so I'm guessing increased temperature increased chemical bleach demand which I did not account for.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    My solar cover has been on for about 3 weeks now and clear as ever Try raising your FC level after you finish the SLAM
    tcat's Avatar
    May 2012
    Austin, TX
    731
    I get a lot of pollen, seems to build up on cover, I brush leaves off cover but pollen trends to end up in pool. Brown "dust" on walls and bottom. Brushing and circulating gets rid of it (after 2 or 3 days).
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    Apr 2015
    19
    Does it make a difference if it's a blue vs clear cover?
    I have a blue cover.
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,236
    A proper test kit, bought a year ago and stored properly, should be fine to use and not too old. You need to find out the numbers for your own understanding of what's happening, and experts here are flying blind if you don't post test results. With algae already growing in the pool, a cover can make things worse if water is warmer, or better if there's less sunlight getting through, but I think the experts here are telling you nicely that the cover is not the cause. I suppose if the cover is dirty with algae, it could be adding to the problem, and would need to be cleaned. Even without seeing test numbers, it sounds like you need to kill the algae in the pool, and then maintain adequate FC.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Donldson's Avatar
    NW Ohio
    2,892
    What are your current test results?
    JayG's Avatar
    Aug 2015
    Harrison, NY
    189
    I hope this thread is not to old to resurrect. I have also noticed that when we roll up our solar cover that inevitably some murky water on top makes it into the pool. When I subsequently measure FC/CC, I've seen a drop in FC (e.g., 9.5-10 ppm >> 5-6.5 ppm) and CC rising from 0 to 1 or 1.5 ppm. I've seen this twice now and have simply left the pool uncovered for a day or so and bumped up the Stenner to deliver an extra 2-5 ppm of FC over the next 24 hours. In each case, the next reading has the FC in a happy place and CC having returned to 0-0.5 ppm. Nonetheless, I've found this tendency of the cover to be harboring mucky water to be disconcerting. I also have the feeling that the cover prevents normal skimming. However, when testing the water when the cover is present, my FC and CC have always been fine. It is just when I remove it that I have problems.
    I'm not sure there is a solution to this problem, but I'd be curious to see whether other people have found a way around this. Here is a log of my FC/CC numbers. The asterisks indicate readings a couple of hours after the cover was removed. Other values: pH 7.7; TA 70; CH 300; CYA 70; Salt 600; borates 50; temp 86-87F
    5/29/2016 10.0 0.0
    5/29/2016 6.5 1.0*
    5/30/2016 8.5 0.5
    5/31/2016 7.5 0.5
    6/1/2016 9.0 0.0
    6/2/2016 7.5 0.5
    6/3/2016 9.5 0.0
    6/4/2016 5.0 1.5*
    6/5/2016 10.5 0.0
    Jay--Metro NYC
    35K gal, in-ground, free-form, pebble finish, 2 skimmers, 3 returns, autofill. No spa, no features. Partial shade.
    Pentair C&C cartridge filter (400 sq in), Pentair VS pump, Pentair 140 btu heat pump, Triton Plus Robo-cleaner; Stenner with 55 gal bleach cistern. TFT 100 test kit.
    JayG's Avatar
    Aug 2015
    Harrison, NY
    189
    Sorry to bump this, but should I be worried about these spikes in CC? I'm thinking I should leave off the cover until it starts getting chilly again in Sept/Oct.
    Jay--Metro NYC
