Thread: Broken Air Manifold Barb?
    Liberty, Tx.
    27
    I was given a 1999 Morgan Daytona hot tub. Its 7 foot by 7 foot and the pack was just changed out a few years ago and still working great. The problem is the entire wood frame and skirt has rot damage. I have it flipped over and building the frame. While pulling the foam off to get the frame to fit I broke a barb off of a air manifold. Is there anyway to repair it without replacing both manifolds and check valve? Also what size is the pipe 1"? If I have to replace both manifolds does it glue straight onto the flex pipe and will normal pvc cleaner, primer and glue work?
    Intex 22' x 52"
    Intex 2500 gph
    TFPC Method (BBB)
    38,262
    Re: Broken Air Manifold Barb?
    I think your best bet would be to try to seal the hole and then move the tub to one of the 3 barbs to the right.
    I do not think you are going to be able to reattach that barb (even sealing it might be tricky).
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,770
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Liberty, Tx.
    27
    Thanks for the help. I just moved the hose to another barb and caped the broken one off. Got the frame finished and got the hot tub flipped back over. Filled it and now I have water dribbling out the black valve on the end of the manifold. Is this a check valve or bleeder and what does it do? More importantly how do I keep water from coming out of it?
    Intex 22' x 52"
    Intex 2500 gph
    TFPC Method (BBB)
