Thread: Foam cove
    Mar 2016
    Chicago,IL
    88
    Foam cove
    So I ordered this foam cove for the bottom as the installer said it would help hold the sand in better...is this a hoax or good insight. Also, it came and the tape doesn't feel sticky at all??? Some of the paper was even peeled off exposing the "glue", or what's suppose to be glue. At this point I think I should just return it and have a sand cove instead. Thoughts???
    19k 15x36' inground oval vinyl lined pool with deep end. 3 returns , 1 skimmer, 1 main drain. TF-100 test kit
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Foam cove
    people love both, there are some that have the foam cove and foam bottom with no sand.. I went with sand under foam... when I had a regular pool I was going to use sand, then foam over sand, then foam cove..
    the nice thing foam cove does is make a uniform cove over the whole pool, sand can be an issue but there are installers who can do sand perfect and some who do not...
    I think I would use foam cove
    Mar 2016
    Chicago,IL
    88
    Re: Foam cove
    Quote Originally Posted by cowboycasey View Post
    shouldnt the glue be sticky though?? Seems like it won't hold well I mean the water pressure should
    hold it but thought I read that it can shift if not sticky? Probably over thinking it.
    Casey's Avatar
    SW PA
    10,428
    Re: Foam cove
    When you put it in, the cove should be butted up against the last piece installed. I have it and used it on 3 pool installs. I'd use it again if I replaced another pool.
    Jun 2015
    Dewinton, Alberta
    73
    Re: Foam cove
    We used the foam cove, and then ran duct tape along the seams on both the top edging and between the pieces of cove where they butt up, to a) help stick it in place a little better and b) to help reduce any creases that might become visible when the liner is sucked tight under the water weight.
    27 foot round above ground pool, steel walls and resin uprights/top rails/foot covers.
    1.5 HP Hayward Turbo II pump, 24inch, 300# Hayward Sand Filter, Hayward 200,000 BTU natural gas heater
    Jul 2013
    Fletcher, OK
    3,353
    Re: Foam cove
    Quote Originally Posted by Countpyro1 View Post
    Nope, not overthinking it It should, StephL had a good suggestion on using tape, the Gorilla extra tough/thick tape is great at lowes..
