Thread: metal framed pools vs. metal walled pools
    May 2015
    spruce pine nc
    9
    A recent wind storm destroyed my Intex ultraframe pool! I have been told to upgrade to a metal walled pool, however, they are so expensive! My question is...aren't metal framed pools just as durable and long lasting as the metal walled? How long can the Intex metal framed pools last? Minus a wind storm, that is! And are Intex pools better than Coleman?
    Intex 22 x 52 ultraframe above ground
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: metal framed pools vs. metal walled pools
    The intex had to be empty, I can not imagine wind moving 100,000 pounds, I have an 32 ft oval and 80 mph winds barely move the side... The intex ultra frame pools are very strong pools but without water they turn into sails i'm afraid..
    you may find a good sale on a new intex ultra frame and sell the pump and filter or replace yours with the new one and have a backup
    Nectarologist's Avatar
    Apr 2015
    New York
    428
    The metal framed are not as durable as the metal walled. I had an ag metal wall and have a friend with an intex. IMO you could not say they were the same quality/durability. The metal wall pool will last 20 years (14 and going strong when I moved). I can't see the intex going that long. But the cost difference it huge like you said. And they both provide the same fun factor!
    Inground, vinyl liner, 16 x 32 (approx. 21k gallons), roman end w/ bench, 2 Jandy LED lights
    Pump: Jandy Flopro, 1.5 hp Heater: Raypak, 266k btu (P-R266-A-EN-C; nat gas) Filter: Jandy C340 (cartridge filter) Robot: Doheny's Dolphin Discovery SWCG: Circupool RJ45
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,557
    The biggest problem I've had with Intex pools is that the legs/rails will eventually rust out long before the liner gives way. But you can buy replacements from Intex and nurse one along for quite some time. My latest 16' Ultraframe is starting its 3rd season with no visible problems yet. For a $300 pool, I'm tickled pink.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
