Results 1 to 8 of 8
Thread: Am I ready for Borates??
    TheBraLady's Avatar
    Jun 2015
    Concord, NC
    177
    I just got my Amazon shipment of Borax today...and also have my MA ready - both amounts according to PoolMath.
    I just tested my water and here are my numbers:
    water temp 69
    FC 7 (I think this is a little high - still trying to "dial in" the SWG
    CC 0
    pH 7.6
    TA 60
    CH 130
    CYA 40 (I hate this test. Seriously. I *think* I finally have the hang of it after several months!)
    I've used Borax in our Spa at 40ppm and I love it. It makes such a huge difference in being able to keep the pH stable.
    So my question for the pool - based on the above numbers, do you think I'm ready to begin?
    Pool Completed 8/2015 18'x36' Gemini shape 3.5' - 8', 19,200 gal IG vinyl, Hayward Max-Flo 1.5 HP 2-speed pump, Hayward Pro Series 300-lb sand filter, Hayward AquaPlus SWG, NO Autofill, Dolphin M400 robot, Taylor 2005 test kit, 434 gal Bullfrog A7L spa
    Sep 2013
    Charleston, SC
    538
    Re: Am I ready for Borates??
    Your TA is a little low per the recommendations on this thread So you want to add borates to your pool--Why and How . For you SWG they should be between 70-80. All else looks good.
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    I would leave the TA at 60. I say go! I like my borates too. Pool and hot tub. Good stuff!
    Here are some helpful pics of the cya test, https://www.taylortechnologies.com/C...P?ContentID=36
    TheBraLady's Avatar
    Jun 2015
    Concord, NC
    177
    Yay! So excited. Thank you so much for your replies!
    38,370
    I agree, your TA at 60ppm is likely fine. Much easier to raise the TA than it is to lower it.
    TheBraLady's Avatar
    Jun 2015
    Concord, NC
    177
    Thank you Jason - that was my hope. My pool seems to "like" TA at 60.
    I got the MA and Borax all brushed in. Should I go ahead and test the pH now - or wait 48 hours like testing the Borate level?
    TheBraLady's Avatar
    Jun 2015
    Concord, NC
    177
    Wow! Less than 24 hours later - and my pool is SPARKLY! I loved it before - but WOW!
    Mar 2014
    Angleton, Tx
    91
    good to hear, waiting to get my TA down and ill give it a try as well
    IG Pebble sheen blue surf approx. 14k gallon, beach entry, 7' spa, 3.5 ton jumping rock/waterfall, Pentair 2hp whisper flo, booster pump, 520 cartridge filter, Stenner Econ T, 400k master temp heater, easy touch controls,TF-100 w/speedstir
