Raise your pH to at least 7.2 with washing soda from the laundry aisle. Or add borax and baking soda. Also, raise your FC. Do you need help figuring out quantities?
This will be my first time ever figuring all these quantities out so any input would be greatly appreciated. I will use the calculator but its always nice to have something to compare to until I get the hang of it.Raise your pH to at least 7.2 with washing soda from the laundry aisle. Or add borax and baking soda. Also, raise your FC. Do you need help figuring out quantities?
I am still draining 1/4 water from the pool. I will start refilling tonight so I can plan for the OCLT test tomorrow night if it is still needed/recommended. I will post back once I get the pool back up and running. Once I get the pool back up and running do I need to go thru all the test again?CYA only leaves by draining and replanting water. Evaporation does not have any impact of CYA or CH.
Here is the link to the OCLT (Overnight Chlorine Loss Test)
Pool School - Perform the Overnight FC Loss Test (OCLT)
It is a good tool to see what is going on in your water if anything.
Kim
Did you get one of the recommended test kits? If so, once filled your first job is to give us the test results: FC, CC, pH, TA, CH, CYA.
And since you had metals in the water before, run a sample down to the pool store and ask them to test for metals. Bring us back the results. If they want you to buy something, make it liquid chlorine or something cheap but don't yet buy any other chemicals there.
Add a gallon of household bleach to the new pool water and let it mix up until we see what else is needed. We're here to help, ok?
Joshua, welcome
I want you to get your FC up and your water balanced per the pool calculator and pool school before worrying any further about metals and the well, but will also be happy to share re same later on as I am also on well with metals and have experimented a great deal
At your current levels you are under the point at which staining readily occurs. I did not have much success with early versions of culator, but others have, btw.
One future reference point will be determining the iron level, as opposed to copper, in your raw well water. Your tap is likely on a water softener but your outdoor spigot is likely raw well.
The copper is most likely from plumbing (uncommon in actual well) but the iron can be quite high from well. And that will be something you will want to watch on refills.
So after you balance your water, please also post back and tell us:
A) which tap you tested, eg interior or exterior
B) if you have a water softener
C) difference between pool outdoor fill spigot iron and in-house spigot iron (some folks on well like me will plumb and outdoor faucet to the water softener system)
- and then I can help give you some tips for managing levels, sequestrant, etc.
Cheers and enjoy your new pool...soon!
