Thread: New Pool cover - Use Old Cover As Template
    off2theocean's Avatar
    Sep 2014
    North Carolina
    12
    Hey All,
    I am in the market to purchase a new cover. I currently have a mesh safety cover that has straps and bolts that hold it in place. I am not sure who manufactured the cover. It is so old that tag that has the serial number has completely faded although it does have "Century" printed around the outer edge of the cover.
    I have been looking online and it seems that the best solution would be to use a company that will make a template from my old cover. This would save drilling new holes and installing new anchors all around the pool. Also, my pool is an unusual freeform shape so it would be hard to measure.
    Has anyone had experience sending in an old cover? What company did you use? Pros or cons?
    Thanks!
    Near Winston-Salem, North Carolina
    33,000 IG Freeform Gunite * Pentair Tagelus Sand Filter * Hayward Pump
    1970's Build * Resurfaced 2015 w/Krystal Blue Krystalkrete
    Polaris 380 Cleaner * TF-100 Test Kit
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: New Pool cover - Use Old Cover As Template
    that sounds like a wonderful and easy way of doing it, But I do not know anyone who has done that... you best bet would be to call some companies and ask them if they will do that.. There may be someone along that has done this
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    I purchased a house with an existing cover. I was lucky and received a post card address to the old owners with the pattern # and asking if it was time to replace the cover.
    You could try contacting the manufacturer and see if they could look up the address to see if they have the pattern on file. Get a quote from them and then compare to other companies.
    Last edited by kcindc; 04-06-2016 at 11:58 AM. Reason: double post within the same post and an odd error message
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    Qwaxalot's Avatar
    Jun 2012
    439
    Loop Loc will make a new cover with the old one as a pattern.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    Mar 2014
    St. Louis
    6
    Raynor will as well, but they only worked through the local Leslie's store. That wasn't an issue and I received a 30% discount.
    25K IG, Gunite, Pebble Sheen, Sand Filter, St. Louis, MO
