Thread: Pool Pressure Testing Concerns
    Apr 2016
    San Diego CA
    2
    Hi - I am getting ready to pour the decking . The system was under pressure for a few months and thoroughly tested before we backfilled the trenches and put in gunite. I want to test it again before I pour concrete. The system was filled to 35 PSI but has a combintation of air and water. It held strong at 35 PSI for about 24 hours but then has moved up and down with changes in temperature. My concern is that it has never made its way back to 35 but is around 33 or 34. There are no visible signs of leaks or soil saturation. Should I be concerned ?
    May 2015
    Fullerton, CA
    636
    Re: Pool Pressure Testing Concerns
    Normal. I had the same concerns, you are getting some pressure leak from a threaded plug at the skimmer or auto fill. If I am wrong then my PB and the City inspector are lying to me. Good with your concrete, hopefully they place it with the correct slump, our deck turned into a nightmare.
    33x19, 3'4"-5'6", 7ft spa, baja reef, 14'x9', 18" deep, 10,668 Gal. Quartzite coping, Stonescape Tropics Blue mini-pebble, abalone & glass beads. Jandy Equip.(JXi heater, 2.7HPVS pump, PLC1400 SWG, CV580 filter, Aqualink, LEDs)
    TF-100, Doheny Discovery robot.
    Apr 2013
    Sacramento, CA
    2,769
    That is normal. You can test it again but it will probably just hold for 24 hours like it did before.
    Apr 2016
    San Diego CA
    2
    awesome... thanks for the replies !! I have enough stressors right now and don't need another
    Tucker020's Avatar
    Mar 2016
    McGregor, Texas
    85
    Quote Originally Posted by chitown_12 View Post
    I'm hoping the joy and relaxation will add the years back that I'm losing over the stress of our build as well.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Yep a nice summer in the pool will take care of all that ails you!
