Thread: Only some jets work!
    Apr 2016
    UK
    1
    Hi,
    Last year we moved into our new home, where the previous owner had left a VitaSpa hot tub.
    We had the spa professionally cleaned & serviced and the pump replaced, and all seemed to be working fine. It wasn't until a few days of using the spa that we noticed that there were 2 or 3 jets that were not working.
    if necessary I will get a professional in to look at it, but I was wondering if there was anything I could do first to investigate the problem. any help or advice would be much appreciated.
    G
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Re: Only some jets work!
    Welcome to TFP!
    Many hot tub jets can be opened and closed individually by rotating the escutcheon surrounding the jet. My tub also has a valve on top that opens and closes flow to about half the jets.
