Thread: Help getting my pool set-up
    It's been awhile since I have been on here. My neighbor and I are trying to set-up his 24' X 54" pool. We have the ground just about level, should be done today. I am trying to find out how much sand needs to be emplaced before we install the pool? Any pointers about things we need to do will be a great help.
    8000 gallon, sand filter, above ground,3/4 Hayward pump
    Mod Squad pooldv's Avatar
    DFW, TX
    24,504
    Re: Help getting my pool set-up
    There is more info in this recent thread about what to put under a pool.
    Novice above ground pool Need help setup intex pool Hayward sand filter aquatrol swg
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    One of my favorite threads about levelling I need advice on leveling my ground.
    Sand has no real structural strength, so I would use the thinnest layer possible to just smooth out the surface so you don't end up with little divots in the floor that collect silt.
