Results 1 to 8 of 8
Thread: Extend lighting conduit
    Apr 2016
    CA
    4
    Hi,
    Just wondering if someone has extended the conduit from the forming shell to the jbox. We're trying to extend conduit to relocate the jbox. Thanks for your help!
    38,305
    Re: Extend lighting conduit
    Welcome to TFP!
    Someone just moved their box a few days ago. You can not have underground wire splices so can not extend it unless you put in a new fixture with longer wire.
    Apr 2016
    CA
    4
    Thanks for the quick response! Will I need to rethread or will a coupling with two direct burial ground clamps with a 8awg to bond the old and new pipe work? Sorry I haven't threaded a pipe before.
    38,305
    I have no idea what the proper procedure is for extending the conduit.
    Apr 2016
    CA
    4
    Sorry I may have forgotten to mention this is a brass conduit
    38,305
    I would think you need to extend the brass. The conduit needs to be water tight as well. I just do not know the related building codes.
    Apr 2016
    CA
    4
    Got thanks! Should i call a plumber to get the brass extended?
    38,305
    I think you need an electrician experienced with pool construction.
