Results 1 to 7 of 7
Thread: pH versus TA
    Nov 2015
    Houston TX
    21
    pH versus TA
    My pool pH goes up constantly. I have been just adding acid but my TA goes to 50 or so.
    I learned about Baking Soda after reading pool school so I started using that to raise TA. I have found that when I get the pH into range, my TA is too low so I add Baking Soda. That raises my pH and I seem to get into a death spiral.
    I seem to be stuck on what to do. Do I just keep adding acid and forget about TA?
    FC 4
    CC 0.5
    CH 260
    TA 80
    pH 8.0
    CYA 35
    Salt 0 (Chlorine Pool)
    Borate 0
    28,000 in ground gunite. 3.5' shallow end, 8' deep end with 8' waterslide. Only metal in the pool is the pool light.
    38,242
    Re: pH versus TA
    Stop raising the TA and the pH will not go up as fast. Aeration will also drive the pH up.
    Mine is down around 50ppm and the pH seems to almost be stable at 7.8.
    In reality just adding, the baking soda should have almost no impact on the pH. But the higher TA, will make the pH go up faster.
    JoyfulNoise's Avatar
    May 2015
    13,173
    Re: pH versus TA
    What pH are you targeting when you add acid to your pool?
    What sources of aeration are you running? I see you have a water slide but are you running it all the time?
    Matt
    Nov 2015
    Houston TX
    21
    Re: pH versus TA
    I haven't run the waterfall or the slide so there is no aeration. I try to get the pH to 7.4-7.6 but I would have to add acid every day to maintain this. I typically add 3/4 of a gallon once a week and let it drift up throughout the week.
    I am using bleach as my chlorine source.
    38,242
    Re: pH versus TA
    I would just ignore the TA for awhile and see what happens to your pH.
    May 2015
    13,173
    Re: pH versus TA
    Based on your current water test results and with a pH no lower than 7.6, you can easily let your TA drop to 50ppm and still be fine.
    So, as jblizzle suggests, stop trying to hold your TA at 80ppm and just target a pH of no lower than 7.6. Do not lower your pH until it rises above 7.8. See how that works out for you.
    Is your plaster new by any chance?
    Matt
    Nov 2015
    Houston TX
    21
    Re: pH versus TA
    My plaster was refinished in 2014. I will ignore TA for now and just focus on keeping the pH correct. Thanks!
