Results 1 to 8 of 8
Thread: First results with TF-100 kit
    Woodberg's Avatar
    Apr 2009
    Houston, TX (Candlelight Estates)
    136
    We completed our pool about 2 months ago and I've been using various methods to keep the pool chemistry stabilized. My PB did the initial work, although, I think they just did the basics. They gave me a ton of chemicals during pool school and I've been using them up while also reading this site and the BBB method. The PB only provided me with a basic chemistry testing kit, so I haven't been exactly sure what my numbers looked like. The pool is clear right now and I want to keep it that way.
    After receiving the TF-100 kit I tested my water and here's what I found:
    FC - 3
    CC - 0
    PH - 7.5
    TA - 100
    CH - 280
    CYA - 30
    Temp - 80
    Since the pool was a new startup, I've been using Trichlor pucks initially to get the CYA up. Should I keep doing this for a while longer to try to get the level a little higher. From what I've read these numbers look OK but you don't know what you don't know.
    20,000 gallon gunite pool, attached spa, Pebblesheen finish, Paramount PCC-2000 infloor cleaning system, Paramount ClearO3 ozone system, Intelliflo VS main pump, Whisperflo 1HP cleaner pump, StaRite cartridge filter, StaRite heater
    Re: First results with TF-100 kit
    Welcome to TFP!
    Your numbers look good!
    I would keep using trichlor tablets till your CYA is around 50.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    If only all pools could have your ideal situation....good job! And Welcome
    Woodberg's Avatar
    Apr 2009
    136
    Thanks for the reply. Is there a way to estimate about how long it would take for the CYA to move from 30 to 50? I'm assuming with the water heating up, that I'll be going through the tablets faster and thereby raising the CYA faster. I'm just not sure how quickly this number an change.
    How often should I be checking the CYA level?
    11,969
    I would check it again next week.
    Jan 2009
    Cupertino, CA
    1,966
    Quote Originally Posted by Woodberg
    The Pool Calculator says it would take about 6 pucks to increase CYA by 10. Just to give you a ballpark for when it would be worth testing again. (I'm doing the same thing right now.)
    --paulr
    BBB "Intermediate Swimmer"
    Woodberg's Avatar
    Apr 2009
    136
    I checked my chlorine level again yesterday, May 4 and got the following results:
    FC - .5
    CC - .5
    We had a lot of kids in the pool on May 2-3. I'm assuming, since I still have pucks loaded in the feeder, that chlorine is still being added to the water. Would these kinds of results seem normal? I'm assuming that the chlorine is being used up from the heavy usage. Is there anything special I should do or should I just wait until the chlorine has a chance to destroy the CC and build back up? Is it normal to see a small percentage of CC's after heavy usage while the chlorine is doing its job?
    Also, with the Paramount ozonater running, my understanding is that its primary purpose is to reduce the CC's down to zero. I'm currently running my pump for 12 hours per day so the oxone system should have plenty of time to work.
    Low FC levels are not exactly uncommon, but they are not good and not something you should allow to happen if you can prevent it.
    At this point, I would add some extra chlorine to boost the level back up to normal manually and then keep an eye on it to make sure the automatic chlorinator can keep up.
    If you are having a swim party, or some similar event where there will be more swimming than usual, it is best to add a little extra chlorine in advance, so the FC level never gets that low.
    If this amount of swimming is common, you should turn up the dial on the automatic chlorinator a little.
