Thread: Temp sensor on a Baja 1042 spa
    Mar 2016
    Chapel Hill, NC
    4
    Question Temp sensor on a Baja 1042 spa
    Hi, I've got a Baja 1042 spa that's showing some signs of a bad temperature probe: overshooting the set point by 8-10 degrees during heating/filtering, and randomly showing 10-15 degrees over the actual temperature, thus refusing to heat. Sometimes the control panel flashes "131F". Cutting power and turning it back on often solves the problem.
    I was thinking about replacing the temperature sensor. I found the sensor and it's easily disconnected, but I am not sure how to choose the right replacement. It is a three-wire device, and looks exactly like this:
    Temperature Sensor - HydroQuip 34-0203
    But I wouldn't mind some reassurance. The cable on the sensor doesn't seem to have any identifying information about the device, just info about the cable. On the control box, there's a sticker that says "33-0025-R5 PCB, Digital, Ultimate, 240V".
    Google isn't helping me much for replacement parts for the Baja 1042; just replacement covers.
    Question one: Do these symptoms sound like a bad temperature sensor?
    Question two: does that HydroQuip part look like a reasonable replacement?
    Thank you! This has been a very helpful forum for both my hot tub and pool!
    -Tim
    PS: I can upload some photos, but I am not sure if they would be helpful...
    Mar 2016
    Chapel Hill, NC
    4
    Re: Temp sensor on a Baja 1042 spa
    OK, I think I've made some progress. I've found the replacement circuit board (Hydro Quip Circuit Board, DIG MP, UNIV, 8-Key, 9700 Series, 33-00) and that page links to a suitable temperature sensor! So I think I will buy that and see if it solves my problem.
    38,305
    Welcome to TFP!!!
    Sorry no one was able to help. Hopefully you just solved the problem for yourself
