Thread: Putty in existing lamp niche
    Apr 2016
    South East USA
    78
    Hi,
    I have a pool that was built around 2005. It has a Pentair wet niche for the lamp.
    I bought the house in 2006, so I am the second owner; the previous owner had the pool for a year.
    I want to relamp with an LED but when I started to research the steps required I realized there is a cone of putty around the lamp cord at the back of the niche.
    I read that leaks from the back of the niche are very common and that putty is a common way to fix these leaks. I have never had a leak but I am wondering if there was a leak during the year the previous owner had it? Or perhaps some pool installers will use putty as a matter of course during installation?
    I'm going to have to try chiseling the putty out so I can upgrade my lamp. Does anybody think this is a folly for a non-mission-critical lamp upgrade - better to leave it alone?
    ft
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,748
    Re: Putty in existing lamp niche
    Some installers believe in sealing the pool from the conduit. It could also very well be plunging a leak in the line...there really isn't an easy way to figure it out.
    Plugging the conduit is a somewhat common practice and doesn't really indicate anything either way.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
