Thread: Hayward Vacuum not working correctly
    Nov 2014
    Palm Desert, CA
    99
    Our Hayward vacuum usually works great. We had a big windstorm and it started moving slowly and staying in the deep end of the pool. My husband checked all the hose sections were clear, checked pump basket was clear (including the pipes coming into and out of pump basket), and we cleaned the big filters. It seems to have gotten a little faster but is still staying in the deep end, and speeds up and slows down as it makes it's way around (stopping then lurching forward). He has checked the feet and there seems to be no obstructions (had new feet put on last year). Any ideas what else we can look for? THANKS
    17,000 gallon inground pool; Plaster redone January 2015; Pentair Cartridge Filter; SWG; Age of pool unknown (house built in 1973); Taylor K-2006 Test Kit.; Doheny Discovery robot cleaner.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Hayward Vacuum not working correctly
    Can you post a model number or picture of the vacuum... it sounds like something is stuck in the suction side that is limiting the flow... can you get a snake down the pipe?
    Is the pressure on your filter the same as before?
