Thread: Anyone install zwave or wifi intermatic switch? How do you handle pump scheduling?
    Jul 2015
    franklin/tn
    96
    I installed the good ol' Intermatic CA3750 zwave switch and I love it!! Finally solved the problem of always flipping the breaker when I need to turn the pump on and off and the zwave/automation is a HUGE plus.
    So at the moment I have set it up to run for 2 hours in the morning, 2 hours in the afternoon and 2 hours at 11pm.
    Because I can have unlimited schedules with the pump now using a smart hub, I don't know what the best way to do this is?
    I assume its better to have more pump action during the day (when its more windy) but rather than a single 6-hour block, it seems to make more sense to run it other times as well to keep newly fallen debris out.
    Is 6 hours long enough? Should I schedule 3 hours blocks instead of 2 hour blocks & run it for 9 hours?
    Any thoughts on my current setup?
    TIA!
    33x15' INGROUND pool roughly 14,800 gallons. liner, hayward multiport, sand filter (S-210S), pentair century 3/4hp pump (1081) & 320 automatic chlorinator. skimmer at one end of pool, 2 returns at the other.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Anyone install zwave or wifi intermatic switch? How do you handle pump schedulin
    So, I just bought the Samsung smart things hub and about to set it up, so I can not tell you anything about that other than I also have the Z-wave in my intermatic.. I run my schedule for the SWG so I do not spread the hours out..
    If no SWG it sounds like a good plan, if 6 hours is cleaning your pool to your satisfaction I would leave it where it is, if it is not then take it to 3 hours
    Jul 2015
    franklin/tn
    96
    Quote Originally Posted by cowboycasey View Post
    check out /homeautomation on reddit for some tips on that.
    i went with Wink so all my experiences are going to be flavored by how that hub works but both are good (and bad)
    i wrote up my install-experience with the intermatic switch, didn't realize how many ways you could configure it until i had all the wires and couldn't figure out what went where.
    i want to adjust my schedules seasonally..running more in the spring with the blooms falling and then if i get into trouble with algae i'll just turn the schedules off completely and run it 24/7.
    last year (my first year owning this pool) i ran the dang thing pretty much non-stop from april to early october and that killed my electric bill. this year i hope to be smarter with it..plus it hurt my sould every time i flipped the breaker just to backwash or anything else. I could feel the breaker wearing out. lol
