Page 1 of 4 1234 LastLast
Results 1 to 20 of 79
Thread: What's One More Pool in Central Texas
    Tucker020's Avatar
    Mar 2016
    McGregor, Texas
    85
    So I’ve been picking your brains with the “Search” feature for almost a month now. Still have a lot to learn (I don’t quite speak “pool” yet), but there’s a gold mine of info on here and what seems to be a great community of people that are passionate about their pools and helping others.With today being “Gunite Day”, I figured it’s as good a time as any to say “Hi”. So….Hi!
    So to catch you all up, we started digging on March 18th, laid steel on Easter weekend, plumbed and bonding on the 28th. So things have progressed rather quickly. They hit a natural spring at the very bottom of the deep end. So when the inspector came out for the steel and bonding…we failed due to him not being able to see the bottom. Got a sump pump out there and ran it this morning to get the water out, and just got verification that we did pass. So gunite crew will be at the house at around 2pm!
    My poor wife had to fly to Nashville on business yesterday, but I set up a webcam overlooking everything so she’ll be able to Skype in and watch from her phone. I’ll certainly update my sig with all the details, and will likely have questions along the way (so thanks to everyone in advance). Enjoy the pics!
    Designer went a bit overboard with the foliage, but you get the idea. Here are the basics: 17' X 33' 8 person Spa 10' X 6' Tanning Ledge Depth: 3.5' - 6'
    Maybe I can take advantage of the natural spring to fill my pool?
    Was NOT happy with where they ended the lines....they will be moving it left another 2 or 3 feet when they pour the pad.
    Inspector on the webcam this morning.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: What's One More Pool in Central Texas
    Welcome, It looks like a great design.. The 1 thing that caught my attention right off is "the natural spring" If they hit standing water you really need them to install some kind of system to allow the water to be drained out from under your pool.. All pools have the ability to "float" out of the ground (they use to have cement boats) I am sure they are installing something, just make sure you know what it is
    Chris19D's Avatar
    Jul 2015
    Cypress, Texas
    89
    You're going to love that and the design looks amazing! Congratulations Tucker!
    ~Chris - 20,000 gallons free-form gunite / Pebbletec, Aquapure 1400 SWG, 2 HP Jandy VS Main Pool Pump, 2 HP Jandy Water feature Pump, 580 Jandy cartridge filter, Dolphin M500, TF-100 w/Speedstir.
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    ^^ Agree, it may be as simple as a couple of holes left in the gunite to allow the spring water to fill the pool rather than float it (like sea valves in a ship)
    When they are ready to plaster they fill them in.
    Once they are filled, they are committed to plaster and fill the pool in quick succession.
    40k gal freeform, IG pebblesheen, 9'x'6' raised spa, 2-1/2 hp Whisperflo, 520 sq/ft cartridge, Legend w/ booster, Intellibrite 5g in pool @ spa, Rainbow 320 Chlorinator(retired),
    Mastertemp 400k BTU, 3x3 hp Whisperflo Swimjets, 2x2 hp Whisperflow for 15ton moss rock waterfall, Intelitouch Controller, 850 sq/ft Travertine deck, Gas/Wood firepit,
    Autofill, TF-100 test kit w/ SpeedStir
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,818
    Looks great! Good luck as the process continues. One comment, if the rendering shows the expected location of post lights, I'll make one recommendation. I'd move them because of the bugs they attract and them being too close to habitated areas.
    I'd move the one by the spa to the lower left corner and the one in the upper right corner, over a few more feet near the palm tree location.
    Ok, two comments...I'd also put them both on dimmers (or one dimmer if on the same switch). Outdoor dimmers are pricey but very worthwhile. I have mine set to go off at midnight through the automation system. So if it's dark out back, I know I've stayed up too late!
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Tucker020's Avatar
    Mar 2016
    McGregor, Texas
    85
    Quote Originally Posted by cowboycasey View Post
    Quote Originally Posted by ozdiver View Post
    That was a huge concern for me and I was sure to ask how they would handle it. PB said that they leave weeping holes in all of their shells, regardless of seeing water or not, just for that very reason.
    Quote Originally Posted by Chris19D View Post
    Thank you sir! I'm certain that we will. 2 kids just starting elementary should make for many great memories.
    Quote Originally Posted by bmoreswim View Post
    Bugs certainly do like light don't they. We are installing the light posts, however not the same as the rendering shows. Ours will have only a single lamp and I am actually going with the Philips Hue color LED lights. We will be able to not only dim them to our preference, but change the color of them to match whatever ambiance we are trying to achieve. I will have them in the post lights, as well as 2 canned lights under my porch. I have them throughout my home and we absolutely love them. I know that Philips will not guarantee that they will be able to stand up to the elements. However I have done some homework and have yet to find anyone that has used them outside, and have them stop working. So it's an expensive chance, but the wife gave me permission to try them outside once.
    They are here now doing their thing...so I'll get some pics and post them up later. Thank you to everyone for taking the time!
    Matt
    Jul 2013
    Fletcher, OK
    3,353
    Are they putting Hydrostatic Relief Plugs in?
    FAQs About Hydrostatic Relief Plugs | Sunplay
    Tucker020's Avatar
    Mar 2016
    McGregor, Texas
    85
    Great info.....will for sure ask about that
    Current situation:
    Kiddo brought those out to them. Learning young to keep the workers happy and hydrated!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Welcome to TFP and congrats on the new pool!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,525
    Good job training the kid! LOL
    Kim
    Tucker020's Avatar
    Mar 2016
    McGregor, Texas
    85
    Quote Originally Posted by pooldv View Post
    Thanks! As you can imagine, we are super excited.
    Quote Originally Posted by kimkats View Post
    Kim
    Definitely a teaching moment.
    So after discussing the "spring" with the PB, he said that it's actually not a spring at all; but rather just a high water shelf. He said he sees it in about 50% of the pools that they do (they cover a 70 mile radius from their home office). They left 4 big weep holes and as of this morning, no sign of water. 5:30am came real quick this morning to get out there and water it for a good 45 mins. I bought a sprinkler and timer, so I'll get to play around with that this evening; maybe buy myself a few more Snooze Button presses.
    Here are some pics of the finished product!
    You can really see the weep holes in this one.
    May 2014
    katy. tx
    80
    Quote Originally Posted by Tucker020 View Post
    Thanks!
    [/URL]
    quick question on the hot tub, more for other experts in here than OP perhaps....
    Whats the opinion on blower connections to hot tubs?
    better to have separate piping for air and water?
    our last home hot tub shared piping for blower and water. meant you could not have both water heating / circulating and air blowing at same time.
    Jan 2016
    Mesa, Az
    541
    That's going to be REALLY nice. Perfect size for the yard!
    Oct 2015
    North Richland Hills, Texas
    191
    Looks awesome! Sweet design cant wait to see the end result!
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    Quote Originally Posted by ibreslin View Post
    Mine has shared jet/blower piping and I can have any combination of heat/bubbles/jets.
    I do have a couple of jets in the spa that are looped in with pool circulation that do not run at all in spa mode.
    Feb 2016
    Houston
    323
    Nice design and size of pool.Have you decided on your plaster and finishes?
    My pool thread. IG 31' x 20', 3.5'/4.5'/6', 8' spa, 4T moss rock WF/WW w/jumping rock, 7' x 11' sunshelf 3 bubblers, travertine coping, spray deck, Hayward equip: SwimClear 525 Cartridge Filter, H400 natural gas heater, Tristar Dual Speed EE pump 2HP, Tristar EE pump 1.5HP for water features, blower 2HP, Prologic P/S 8 w/aqua pod remote, Aqua Rite T-15 Salt System, Tigershark QC robot, networked Colorlogic LEDs 2 pool 1 spa.
    Tucker020's Avatar
    Mar 2016
    McGregor, Texas
    85
    I'll definitely defer to the experts on this one.
    Quote Originally Posted by BigEinAZ View Post
    Quote Originally Posted by bankOman View Post
    Quote Originally Posted by firehunter View Post
    Thanks! There's actually a lot more yard on the other side that stretches down the side of the house into the back yard. Unfortunately that's also where they had to bring the heavy equipment in. So that will all need new irrigation lines as well as sod. As for the plaster/finish, we are going with Stonescapes. We aren't fully decided on regular or mini pebble (any and all replies on experiences with either are welcome and most certainly appreciated). PB has regular pebble and swears by it, however his daughter has mini pebble and says he's a crazy old man.
    Also we have narrowed the color down to Tropics Blue, Tahoe Blue, and Midnight Blue. We looked at a pool Saturday that had Midnight Blue mini pebble and I have to say, I liked it a lot more than I thought I would. PB's daughter has Tropics, and her friend just down the road from her has Tahoe. So we will be seeing those in person soon.
    Jul 2012
    Tallahassee, FL
    30,525
    Do you KNOW how lucky you are? To be able to see your pics in real life is a dream come true for many pool builders!
    Can't wait to see it !
    Kim
    Tucker020's Avatar
    Mar 2016
    McGregor, Texas
    85
    Kim
    Absolutely fortunate to be the one making the decisions on the final product (or at least my wife lets me think I'm making the decisions). I know many people with pools; yet none were a part of the construction of it. Definitely won't take that for granted.
    My Build Thread 16' X 33' Freeform 3.5' - 6' depth 8' Round Spa StoneScapes Midnight Blue Mini Pebble Noble Tile - Pietra Lavica (Lipari) Tile Oklahoma Flagstone Philips Hue Color LED's in Light Poles Hayward Tri-Star Hayward Sand Filter Hayward Navigator E-Command 4 control panel w/ remote 725 sqft washed aggregate decking
  20. Back To Top    #20
    May 2014
    katy. tx
    80
    dunno what was going on with mine then, air never made it thru the piping when the water was circulating. I ended up never using the bubbles, the bubble noise was a big deal but the best feeling ever was feeling the heat kick in on the water jets on a chilly day.
