Thread: Starting With Tap Water
    Jul 2014
    Joplin, Mo
    35
    I have been running TFP for 2 years and have had amazing success, Thanks guys!!!
    This year I drained the pool to do some pressure washing on a few old stains, some grout work where it was pulling away, and pull through a new light. I am about to add new clean water and want to see if there is anything I should be doing while filling or do I just fill it up, take my readings and treat it like water I found when I did a normal spring opening?
    22,000ish gallon concrete pool.
    Taylor K-2006
    Sand Filter
    Joplin, Mo
    38,295
    Re: Starting With Tap Water
    Just fill it up and treat like normal.
    You know you will need CYA, so you can get that dissolving right away.
