Thread: Hayward OmniLogic Low Voltage Relays
    Apr 2015
    Tulsa, OK
    11
    Does anyone know the specs on the Hayward OmniLogic Low Voltage Relays? Other than they are listed at 24v, I can't seem to find any other useful information on the relays. I'm curious if I can add a string of 24v LED rope lights to one of the low voltage relays in the OmniLogic. Does it have enough amps for such a connection, or do I still need a 120v transformer connected to a high voltage relay for this to work?
    At present I only have the heater connected to a low voltage relay, and that's only for the "control" wire, it has a separate 240v connection (not on a high voltage relay) for power. If low voltage lighting won't work on these relays, what else is supposed to connect here?
    Thanks.
    44k gal, IG gunite/plaster, spillover spa, waterfall features, OmniLogic automation, TriStar VS pump (filter), 1.5HP TriStar pump (waterfalls), Hayward S310T2 sand filter, TurboCell-15 SWG, Hayward H400FDN gas heater, Dolphin Z5 cleaner, TF-100 test kit.
    Apr 2013
    Sacramento, CA
    2,769
    Re: Hayward OmniLogic Low Voltage Relays
    Valve actuators. Generally, the low voltage relays inside pool control systems are designed to turn valves or run other relay controlled equipment.
    Sep 2015
    Orlando, FL
    33
    Its basically an "on/off" switch. I have a transformer powering several different types of 12v lights, and ran each location to its own LVR. The omni lets me instantly turn all of these areas on as needed
    16k gal, IG, marcite, 3HP VSP Ecostar, 2HP Booster 2speed, 200 sqft cartridge, SWG, Caretaker IFC, Omnilogic, Solar, Taylor K2006, Born 3/16
    Apr 2016
    Levittown pa
    1
    Quote Originally Posted by XSurfX View Post
    The problem with the lv relays is you can use them for lights. well you can however when selecting lights to program your omnilogic only hv relays are able to be chosen. So you would have to choose another section in programing such as heater and rename it light to use the lv relays in this fashion.
    The way to properly use the low voltage relays for lights is to have a 24v transformer send power to the lv relays. Then dumper down them for as many you would like to use. Then from the other side of the lv relays have them control and external 24v relay which in turn controls the transformer for your lights. but as I stated early you cant choose the lv relays in the lights drop down menu when programing. I have spoken to Hayward to have them adjust their programs but as of yet they will now. reason is they make to much money selling your those over priced hi voltage relays.
    38,235
    Quote Originally Posted by Cronoglous View Post
    Welcome to TFP!
    Unfortunately, I think there are so many typos in this I am not sure what you are trying to say. Can VS. Can't, etc.
    Sep 2015
    Orlando, FL
    33
    I just realized that I did end up wiring my lights to the high voltage relays because of the programming issues.
    Basically ran a hot 12V from transformer to each HVR, and ran back the hot to each lighting section. Works awesome, and so far I haven't set my house on fire.
    I ended up needing the expansion panel and the relay bank...the stock omnilogic is pretty limited in actuator and HVR control.
    So far I really like it. The web access works well, the app I don't trust for control away from home.
