Results 1 to 14 of 14
Thread: What do you use to shield Stenner tank from the sun?
    Apr 2015
    South Central PA
    297
    Soon I'm going to install a Stenner auto feed system with the grey 15 gallon Stenner tank. The equipment pad gets primarily morning sun. Some people have said they used a trash can to shield from direct sun. I was planning on buying a light colored trash can and leaving the top open or turn it upside down and louver the top. However, I can't find and light colors anymore....seems they're all black or gray, which will just absorb the heat.....I know I can build something, but I'd rather not spend the time if there are better ideas out there....and suggestions?
    20000 gallon vinyl liner in ground pool
    16' X 34' rectangular diving pool
    Hayward Pro Grid DE Filter
    Hayward 1 hp Super Pump
    TF-100 Test Kit Stenner 45MPHP10
    30,414
    Re: What do you use to shield Stenner tank from the sun?
    Short of building something that looks nice, you might be able to find an end table (outdoor furniture) that is waterproof and do the job. I am not sure how nice that would look, however.
    Mar 2015
    South Texas
    411
    How about a light grey trash can?
    Grey Plastic Trash Can at FoodServiceDirect.com!
    15,000 gallon free form Viking fiberglass pool. Hayward Star-Clear Plus C12002 cartridge filter. Hayward Swim Pure Plus T-15 SWG. Testing with TF-100 Kit. 2 speed 1.5HP Supreme pump. Dolphin Nautilus robotic cleaner
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    What's wrong with painting a trash can white? Just scuff it up a little so the paint has something to bite.
    Apr 2013
    Sacramento, CA
    2,769
    Man I would have to move if my wife found out I covered the Stenner with a trash can!!!!
    Mar 2015
    Sugar Land , TX
    424
    My trashcan is dark brown and will get hot on outside but 15 gallon tank inside is cool.
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
    Apr 2015
    South Central PA
    297
    Thanks for the responses....I guess I just assumed a black/gray can would heat up excessively, but I'll give one a try...and paint it a light color if it doesn't work. I like the light gray one, but between the cost and shipping, it's getting very expensive for a trash can.
    Richard320's Avatar
    Jan 2010
    18,984
    Quote Originally Posted by 440dodge440 View Post
    You can pick up a Rubbermaid trash can at Lowes or Home Depot. Why pay shipping?
    Apr 2015
    South Central PA
    297
    That was a response to the link in post #3...I checked online- the Lowes & Home Depot near me do not have light colors...but since the plan changed, I'm not limiting the search to light colors...
    JayG's Avatar
    Aug 2015
    Harrison, NY
    189
    I am burying my tank to keep it cool. I need to finish the install with some insulation around the upper 2' of the tank and then backfill with gravel and sand. I'll finish it off with some sort of cover to keep rain out. I'm hoping to keep the average temp of the contents below 70 F. I'll run the Stenner tubing inside a flex duct or PVC that is clamped to the pad to keep it out of harms way. I paid $35 locally for the HDPE drum, $10 for some rigid foam board, and $100 for my gardener to dig the hole.
    That said, containing the tank in a trash can is easier.
    Jay--Metro NYC
    35K gal, in-ground, free-form, pebble finish, 2 skimmers, 3 returns, autofill. No spa, no features. Partial shade.
    Pentair C&C cartridge filter (400 sq in), Pentair VS pump, Pentair 140 btu heat pump, Triton Plus Robo-cleaner; Stenner with 55 gal bleach cistern. TFT 100 test kit.
    DonW's Avatar
    Jun 2008
    Central IL.
    96
    You could go nutz...
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    18' x 33' AGP
    16,715 gal.
    200 lb. Sand Filter w/Hayward PowerFlo MATRIX 1.5 H.P. 2 Spd. pump
    Stenner Injection Pump System
    JayG's Avatar
    Aug 2015
    Harrison, NY
    189
    Very well done sir!
    Jay--Metro NYC
    merkurmaniac's Avatar
    May 2014
    Sugar Land, TX
    17
    Mine was some kind of weatherbeaten deck box from suncast. It was sunbaked and gray. I cut the bottom out of it, since the tank would crush the old plastic bottom. It sits directly on a piece of thick travertine. I primed it and then painted it with latex house paint to match my house. The lid works nicely. I dremeled a hole for the outlet tubing.
    23,000 gal Liq. Cl in ground plaster pool. CC150 filter with ECM27SQU VFD pump and polaris cleaner. Second pump for water feature.
    Jan 2016
    Pearland, Texas
    12
    I just built an enclousure out of thin plywood and painted it with outdoors type paint. Simple and effective. Painted it with white paint for reflection. It keeps the tank cool.
    Finished December 5, 2015. 26,000 gals IG pool w/ 7 ft. dia. Spa, WetEdge Plaster, Intelliflo VS main pump, Whisperflo pump for 5 Scuppers. Cleaner booster pump, Pentair EasyTouch 8 panel, Rainbow 320 chlorinator, FNS 60 DE filter, Pentair Racer, 3 Intellibrite LED's, StaRite Max-e-Therm 400k heater, Stenner chlorine metering pump, FloVis flow meter.
