Results 1 to 14 of 14
Thread: What size sand filter , 40k gallon pool
    Oct 2015
    Spanish Fort , Alabama
    45
    Was pretty much dead set on a cartridge filter , but I really think I want the ease of a sand filter .
    what size should I go with ? Thinking the Pentair 600lb with 2" plumbing .
    Any other recommendations? Would like to stick with Pentair .
    38,371
    Re: What size sand filter , 40k gallon pool
    BIG!!!
    My little calculator that I use suggests a minimum of 36" diameter (not sure how much sand that is). You could get by with smaller and just have to backwash more often.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Go with a 36" SF no question. My Pentair holds about 925 pounds of sand.
    Essential Links:
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    I'll be the echo chamber here and say: "Yep! 36" sand filter would be a great size for your pool." Make sure you have room on your pad for it. I was going to go for a 36 inch when I replaced mine, but there wasn't room to sandwich it in between my heater and pump.
    Isolated Spa - 345 Gallons
    Oct 2015
    45
    Ok , so I'm looking at the Pentair TR140c and the Pentair TR140c3
    c3 says commercial , and has flanged fittings instead of threaded .
    so I'm guessing these won't be overkill?? Will have to do some more checking to figure out what valve goes on the 140c3
    Feb 2014
    Central Minnesota
    5,080
    They won't be overkill for a pool that large. You'll likely only have to backwash every 3 months, maybe not even that often if you consistently maintain good water chemistry and don't have a lot of dirt, pollen, etc. going in your pool.
    You'll be happy with a side mounted valve set up. They're more reliable over the long term than a top mounted valve (like mine). It should come with a multiport valve (MPV), in either 1.5" fittings or 2" fittings. Get the option that matches your plumbing for the pool.
    Oct 2015
    45
    Looks like the 140c is the commercial version , and the 140 is the consumer .
    The commercial is just a little harder to find , and a little more money
    30,426
    I've got the residential TR-140 and it has been bulletproof in my 42k pool.
    Oct 2015
    45
    You talked me into it ! Ordered mine today !
    ellsian's Avatar
    Jun 2014
    Peoria, AZ
    216
    wow, you guys gotta post some pics of these ginormous pools!
    Swim ready :) My Pool Build Thread. IG shotcrete 34x16 Grecian shape. 22k gallons. 3'6 - 8'6 deep. 12x5 Baja ledge w/ 2 Bubblers, 14' raised beam sheer descent waterfall in stacked rock. Custom stone diving board. Hayward sand filter, VS pump, Aquarite T-15 SWCG. A&A In floor system w/ Gamma 4 venturi heads, Blue surf Pebble sheen, Colorlogic LED. Future Travertine Sandcastle Owner.
    30,426
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    Only 27K gallons here...with a filter that is bit smaller than I'd like (should have known better).
    Untitled by Snowman 10, on Flickr
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    Wow!!! Is that YOUR pool or the neighborhood pool? That is awesome!!
    Denise-TFP Guide
    IG 13.6x30 gunite, Radiant Fusion Topaz, 3.6/5.6/4, 14100 gal, 2 skimmer, 4 Hayward LED lights (pool & spa), Hayward Echostar VSP, 2 future fire bowls, raised beam wall w/ scuppers,7x7 raised spa, DE Progrid70, SWG Hayward Goldline, OmniLogic, Hayward 400K BTU heater, stamped colored deck, Dolphin Discovery robotic cleaner, TF100 test kit, Newbie in Bixby Oklahoma
    30,426
    It is actually now my daughter's who lives there with spouse, a nine y/o and a five y/o.
    It gets far more use now. They like big parties and the pool has been fun for us all.
