Results 1 to 8 of 8
Thread: Proper test kit
    Mar 2016
    Chicago,IL
    88
    Proper test kit
    I ordered a k-2006 kit recently but after further reading it seems the tf-100 kit seems more appropriate. This is my first pool and is a brand new install. I've always had a family pool growing up but never managed the water. I paid $60 for the k-2006 but contemplating spending another $100 for the tf-100 and speed stir. Figured it's cheap considering the investment and will save $$$ in the long run. Am I on the right track? Should I return the k-2006? Is it worth hanging on too?
    19k 15x36' inground oval vinyl lined pool with deep end. 3 returns , 1 skimmer, 1 main drain. TF-100 test kit
    Jun 2014
    15,298
    Re: Proper test kit
    The K-2006 will be fine. If you need to SLAM and test a lot, you may want to order extra reagents (FAS-DPD kit) though. Otherwise, the K-2006 will give you accurate results. You should however order the speed stir. That makes mixing with either kit much better.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    Re: Proper test kit
    Ordering the TF100 and having the K-2006 will probably keep you in tests this summer and next summer.
    38,548
    Re: Proper test kit
    I would just keep the K2006 and order the SpeedStir and FAS-DPD and CYA refills.
    JoyfulNoise's Avatar
    May 2015
    13,265
    Re: Proper test kit
    Ditto. Just order the refills as-needed. It's all the same chemicals and test procedures.
    Matt
    hellstorm2004's Avatar
    Jul 2015
    Richardson, Texas
    182
    Re: Proper test kit
    K-100 is an excellent kit. If you already have 2006, it should be fine. I have the 100, with the speed stir. To be honest, I have not opened the speed stir in 1 year of testing. Its still brand new and in the package.
    Purex Titron FNS DE Filter 25000 gallons approx.
    Century A.O. Smith B855 56Y 2HP Motor. 40x25 (approx). Plaster surface.
    TFT-100 Test Kit.
    Rainbow Lifeguard 320.
    DX5+S Cleaner.
    Mar 2016
    Chicago,IL
    88
    Re: Proper test kit
    Well all this talk of this infamous tf-100 kit made me want....
    Returned the 2006 thru Amazon and ordered the 100 w speed stir and borate strips just in case.
    Package arrived today and I couldn't be happier
    Jun 2014
    15,298
    Re: Proper test kit
    We aim to please. If you have any questions with your new toy, let us know.
