Thread: Swg backwards?
    Swg backwards?
    Is there a reason for this besides an idiot installation? It's between the filter and the pipes to the returns/ water features.
    Built Aug 2015- 20x40 26000 Gallon free form gunite, White plaster w/ 50% blue quartz, 2hp Jandy Stealth, Polaris 280, 2 skimmers,2 floor drains, 5 returns, bubbler, Grotto waterfall. 2 24" sheer decents, Jandy 48 DE filter, Jandy Aquapure PLC1400 SWG, 2 Color changing led
    Re: Swg backwards?
    It will work either way. However, the arrow shows the preferred direction.
    Support the site
    Jun 2014
    Roseville, CA
    343
    Re: Swg backwards?
    I've had my Circupool both ways and there is no difference. I wonder if the temperature reading is affected since one way is pre treatment, the other way post treatment.
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
    Re: Swg backwards?
    Thanks
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    Re: Swg backwards?
    I have a different SWCG but every time I inspect the cell I change the direction I mount it to reverse the flow. Just figured it might help a little in the long run.
    11K gal IG screened-in plaster pool w/ spa
    pentair 150 cartridge filter, Pentair Intelliflow VS pump,
    Aquarite AQR15 SWG, AquaCal Heatwave Heat Pump, TF-100 test kit
    May 2008
    NE Florida
    51
    Re: Swg backwards?
    easy enough to correct. just unscrew it and reverse the installation direction. Seem like the installation manual gave some explanation for this but I don't recall.
