Thread: Slamming with CYA at ZERO
    Marci M's Avatar
    Jul 2015
    Kapolei, Hawaii
    92
    I have started to SLAM my pool, but my CYA is at zero. I tested it with two different test kits just to be sure.
    Is this okay or should I be adding stabilizer at this time?
    Aloha,
    Marci
    13 K gallons, in ground, rectangle, 14 x 30 Vinyl, single main drain, Sand filter, Hayward Tablet Chlorinator, Pentair Pump
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: Slamming with CYA at ZERO
    They usually recommend at least 20-30 CYA so your FC holds during the day.
    Jun 2014
    15,292
    Hello again Marci. Yes, definitely hang a sock with some granular stabilizer in there or else your bleach will disappear quickly to the sun. You can start with a target CYA goal of 20 just so you can maintain a lower SLAM/Shock FC level of 10. After the SLAM is completed, you'll probably want tin increase the CYA to 30-50 depending upon the amount of sun your pool receives. Follow everything listed on the SLAM page and you'll do well. Good luck!
    Aug 2014
    Northern IL
    4,615
    Great to hear from you Marci!!!!! You were a champ last season so I am sure that your new issues will go smoothly!
    If you have started slamming, are you getting an FC reading within say an hour or so or does it basically disappear right away?
    Aug 2014
    Northern IL
    4,615
    Hey, Marci! What's up?
    30,432
    What is your FC level to start that SLAM?
