Thread: Zodiac DuoClear clorine generator - replacement cartridge
    These units have an unusual feature in that they have a replaceable cartridge that spits out small silver/copper particles allowing the chlorine levels to safely fall to .6ppm (so they claim). Probably the same technology available in several washing machines you may have heard about. I have been running this unit for a year .... certainly have had no problems balancing and opening this year was a breeze.
    The cartridge is supposed to be replaced every year ($99) or the chlorine levels need to be bumped up to the 1-3ppm level.
    Any one else running this units and decided if the yearly replacement if worth the effort and cost .... i suppose if anyone were really sensitive to chlorine they would be happy to!
    KC
    REF:
    http://www.zodiac.com.au/chlorine-ge...on-system.aspx
    KC in Ottawa, Ont. Canada........62.5k L(16.5k us gal) IG Vinyl Pool. 18 x 32 Odysee II. Hayward S270T sand filter and 1.5hp pump. Zodiac Duo Clear 130 Salt System(up to 130k L), Raypack Digital Pool Heater.
    Re: Zodiac DuoClear clorine generator - replacement cartridge
    I don't reccommend replacing the mineral cartridge. Copper can cause unsightly stains and if you don't test the metal levels there is no way of knowing if you are even at aneffective level. Simply raising the FC level slightly is more reliable and usually less expensive.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Not a fan of the duoclear for a lot of reasons.
    - Don't believe in N2 cartridges.
    - The combination is just a good excuse to sell a less powerful unit for more money.
    - The housing feels like a toy.
    - It's awkward to plumb in.
    - I once waited 13 MONTHS to replace a brand new housing under warranty that leaked from the factory.
    The only thing I like about it is that the cell looks cool and is VERY easy to remove.
    Guest
    This thread will explain why copper/silver systems are not such a great idea (and in case you are interested, the cartridge just contains copper sulfate and silver nitrate!)
    alternative-sanitizers-and-chemical-free-pools-the-truth-t3025.html
