Thread: Water features pump
    Feb 2016
    Houston
    323
    Water features pump
    We will have a 3 ton moss rock waterfall with 5' weeping walls on each side and 3 bubblers in the sun shelf. PB is recommending a Hayward Tristar EE pump & motor, 1 horse power. Is 1.5 HP the right size? The price is the same as a 1 hp. Does it need to be 2 speed or will we be able to adjust the flow someplace?
    My pool thread. IG 31' x 20', 3.5'/4.5'/6', 8' spa, 4T moss rock WF/WW w/jumping rock, 7' x 11' sunshelf 3 bubblers, travertine coping, spray deck, Hayward equip: SwimClear 525 Cartridge Filter, H400 natural gas heater, Tristar Dual Speed EE pump 2HP, Tristar EE pump 1.5HP for water features, blower 2HP, Prologic P/S 8 w/aqua pod remote, Aqua Rite T-15 Salt System, Tigershark QC robot, networked Colorlogic LEDs 2 pool 1 spa.
    38,539
    Re: Water features pump
    For water features, you need s large amount of flow, so that pump is likely fine. No reason for a 2 speed unless you were going to try to run at lower flow rates. You could put valves on the pipes after the pump to restrict flow to the features, just never close them all
    Feb 2016
    Houston
    323
    Thank you. I think I would probably like to be able to adjust the flow, so I will ask the PB about valves.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,672
    In case I forget to say this later............make sure to run them EVERY day for at least 5 mins to keep the water clear in the lines. You do not want it to become stagnate.
    Kim
