Thread: Bubbler extension for tanning ledge
    Dec 2015
    Dallas, TX
    40
    In a pool remodel I want to add a tanning ledge with a couple bubblers. But in friends pools, a standard eyeball return has difficulty raising the water much past the surface. Pentair has a Colorcascade bubbler with a rubber nozzle extension that can come as close as you want to the surface.
    I don't want the LED lighting, just the nozzle extension for a return in the deck of the tanning ledge. Pentair sells an accessory kit (590048) for Colorcascade with fitting and nozzle extension that they say will fit a standard threaded return, but it is $70-90 online. My pool remodeler says no local distributors have this, so I am on my own trying to find something.
    An older thread had a similar issue, but the recommended Waterway fitting does not have the nozzle extension that I need.
    Bill.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Re: Bubbler extension for tanning ledge
    Here are a whole bunch of eyeballs. You might get enough additional velocity to get some bubbler action just by going to a return with a smaller orifice.
