Results 1 to 8 of 8
Thread: Intex Deluxe Skimmer on a Summer Escapes 10' Quick Set Pool
    Mar 2016
    UK
    3
    Question Intex Deluxe Skimmer on a Summer Escapes 10' Quick Set Pool
    Hello,
    Could anyone tell me if an Intex Deluxe Skimmer will fit, or can be modified to fit on the inflatable ring on a Summer Escapes Quick Set 10' pool? I am asking this as from looking at photos of the Intex Easy Set pools, the inflatable ring looks to be bigger on them (I am not sure if this is true though).
    Kind Regards,
    TonyJr
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: Intex Deluxe Skimmer on a Summer Escapes 10' Quick Set Pool
    Welcome to TFP!
    I don't know for sure, but I would bet a dollar that those pools are made in the same factory with a different name on the side. It looks like there is enough give in the pool and adjustment in the skimmer to make it fit fine.
    Mar 2016
    UK
    3
    pooldv, thank you for your reply. I will purchase one and report back on how it goes. If it does not fit, I will 'encourage' it to fit.
    TonyJr
    3407L Summer Escapes Quick Set 10' Pool, Intex 1600GPH Sand Filter / SWG AIO, Glass Filter Media, 25mm Thermatex Floor Insulation as Base on top of 1" of compacted Bulder's sand.
    Essex, UK.
    DFW, TX
    24,509
    Good plan! Get a bigger hammer!
    Casey's Avatar
    SW PA
    10,457
    Quote Originally Posted by TonyJr View Post
    TonyJr
    I laughed way to hard at this!
    Mar 2016
    UK
    3
    No hammers or brute force required for this to fit - the adjustments on the arm made it clamp on pretty tight, and it works fine. It looks a bit out of place in this size of a pool though .
    All I need now is the proper Intex outlet adapter with a thread on it, which I have ordered. I don't think the Mrs will appreciate the pile of bricks that I currently have holding the outlet pipe at the correct angle for the vacuum to hold the adapter onto the useless Summer Escapes outlet strainer. If they were pink bricks on the other hand...
    TonyJr
    Essex, UK.
    Casey's Avatar
    SW PA
    10,457
    Spray paint is your friend!
    DFW, TX
    24,509
    LOL! Put a bow on it! Glad it worked out.
