Results 1 to 8 of 8
Thread: Prime sand filter????
    Mar 2016
    miami
    3
    HELLO I JUST BOUGHT A SAND FILTER WITH THE PUMP FOR MY POOL BUT IM A LITTLE CONFUSED...HOW WOULD I PRIME THIS BEFORE STARTING IT ??
    30,403
    Re: Prime sand filter????
    Is this an above ground pool?
    (Please use upper/lower case letters...Thanks!)
    Mar 2016
    miami
    3
    Yes it is an above ground pool
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    The way i did it in the above ground we had growing up, I would turn the garden hose on
    then turn on the filter and put the house into the inlet until water comes through.
    Not sure that is the correct way for yours, but it was for the one we had.
    Dolphin E10 Cleaning Robot.
    banditig's Avatar
    Sep 2015
    Ohio
    466
    I would fill it before turning on the pump.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    30,403
    It should prime from gravity. Is water not getting to the pump?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    If you have an above ground pool, and the filter isn't located way uphill, then it should fill up with water naturally because the water is above the pump and filter. If you have any shutoff valves in the lines to and from the pool, make sure they're open. Then turn the valve on the filter to "rinse" and turn the pump on. The pump should start pumping within a couple seconds and all the dust from the sand should wash out the waste pipe. When it looks clear, shut off the pump, turn the valve to filter, and turn the pump on. Boom. You're in business.
    banditig's Avatar
    Sep 2015
    Ohio
    466
    In start up after winter I have had an air-lock in the pump basket the first time, have to turn off pump and release the air in the top of the basket lid. After that its good the rest of the season, maybe because the filter is full of water.
