Thread: Need Polyquat 60~Where to Purchase??
    Jul 2007
    Fort Worth, TX
    19
    I am going to do the ascorbic acid treatment and want to add Polyquat 60 to avoid algae problems. Where is the best place to purchase?
    TIA
    Horses make me smile. :)
    16K gallon iregular SWG w/spa, Aquarite, Legend Cleaner
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Need Polyquat 60~Where to Purchase??
    Do you have a Leslie's Pool buy you? They call it "Leslie's Algae Control" - look for 60% on the label and verify with the store employee that it is the equivalent to Poly 60. That's where I bought mine. Otherwise check the internet?
    Jul 2007
    Fort Worth, TX
    19
    Quote Originally Posted by frustratedpoolmom
    Yes, I do have a Leslie's near by. I will go there today and look and will definitely verify. Probably will pick up sodium thiosulfate there too. Thank you!
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    pinch a penny has it also. it's part of their ABC pool care plan and is called All in One algaecide. it's also $42/half gallon which is a major reason I looked for and found this forum. now I know I shouldn't need it if I'm able to stay on top of things. does anyone know shelf life of this product? I'm still using it but I have an fas-dpd test now so I can make sure my chlorine levels are high enough vs my cya level, so maybe I'll shelve it until I need it for a vacation or something like that.
