Results 1 to 8 of 8
Thread: What's wrong with pool overflowing?
    Ronald U.'s Avatar
    May 2015
    Pearland, Texas (near Houston)
    93
    I always hear of people running outside in the middle of storms to turn on their drain pumps. What's wrong with the pool being up to brim and running over a bit? Thanks.
    In-ground gunnite, 24k gal., Hayward DE filter, bleach, borate, Hayward Tiger Shark robotic cleaner, 75% full sun
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    Re: What's wrong with pool overflowing?
    In your case, probably nothing. If you had a vinyl lined pool, water might get down between the liner and the wall. If you have an above-ground pool, there will always be a low spot, even if it's only 1/16" and that's where the water will drain. That area will end up getting softer than the rest, which may make the pool sink on that side, which makes it drain more, and eventually the pool is visibly off level and might collapse.
    I like to drain in advance because I divert the rain gutters to my pool to reduce the CH buildup. If my water is 2" too high, I'd rather lose 2" of saturated water than 2" of diluted water.
    Ronald U.'s Avatar
    May 2015
    93
    Thank you, sir. Now I understand. And that's why I am here in the first place: to increase my understanding of pool-ism.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    I think the biggest problem is that skimmers don't work when the water is high. All of the junk in your skimmers will go back into the pool when the water level gets to a certain point, maybe at 3/4 up the skimmer opening or so. Until the water gets back down to that point no skimming.
    bbrock's Avatar
    Apr 2014
    Livermore, CA
    574
    +1 re: pooldv's statement. I have found that my skimmer does not work as well. In advance of storms, I will go out and throw in my three-quarter horsepower sump pump to drain the pool some.
    duckvader's Avatar
    Apr 2015
    Mt. Washington, KY
    16
    I just had my pool put in last year and I was amazed how quick the water level would rise during a heavy rain storm. I have a safety cover on mine now and I have had to drain mine several times over the winter due to it getting close to over flowing from rain and snow.
    22k gal 18'x36' Rectangle In Ground Vinyl Lining
    Hayward Pump and Filter
    Hayward AquaRite T-15 SWG
    Polaris 280
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,280
    If they have a saltwater pool, or high salt in a liquid chlorinated pool, they might be draining to keep the salt out of the landscape, in addition to the reasons mentioned.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    There is a joint between the top of the tile and the coping, or cantilever that you do not want flooded. The water can travel through that joint (even if it has been sealed with grout, mastic, or another type of sealer) and you can develop a scenario where your decks could move from the water intrusion. In some cases, not a lot of movement, but any movement is not good. So we say try to keep the water off that joint.
    If you have an auto cover, you want to keep water off of it. Too much water will 1) Put undue stress on the cover (weight of the water) and 2) that weight and volume will actually displace water in the pool. Forcing it over the cover box wall and out the box drain. Then when you finally drain the water off the cover and if you don't open the cover, you could miss the fact that your pool is now low on water and will have a problem with the pump not being able to prime.
    Factory Warranty Station for:
