New Pool Questions???
New here. We are planning on putting in this pool shortly from The Pool Factory but have not ordered anything yet:
[h=2]My Pool Package ™[/h]
Edit
https://www.thepoolfactory.com/wiza...rb3V0L2NhcnQvaW5kZXgvd2l6YXJkLzQ3MDEvcXR5LzE,
24'x54" Saltwater LX Round Pool $2,007.001
$2,007.00
Hayward Thru-Wall Skimmer & Return Fitting $0.001
$0.00
24' Round Peel N' Stick Foam Pool Cove $89.001
$89.00
24' Round Pool Wall Foam $69.951
$69.95
AquaPro 200 SQ. FT. Cartridge Filter System 2-HP 2-Speed Pump 2 Year Warranty $549.001
$549.00
Main Access Pro Series In-Pool Deck Ladder $44.991
$44.99
24'x54" Round Uni-Bead Beach Haven Liner - 30 Gauge $275.001
$275.00
Solaxx Saltron Retro Jet RJ Saltwater Chlorine Generator - 2 Year Warranty $429.001
$429.00
Aqualuminator Above Ground Pool Light 98605000 $99.991
$99.99
9" x 24" Ladder Mat $8.991
$8.99
We live in the country on a farm so there are no neighbors or regulations etc. We would like your wisdom on the equipment above and The Pool Factory as well. I plan on installing myself: level ground, add layer of small crushed rock (1/4 in.), pool on pavers, add inch of pink foam. Please share your opinions and advice freely, I do not have feelings :)
Welcome! :wave:
Do you get a lot of blown dust? A sand filter is the easiest to clean; flip the switch, turn the valve, flip the switch again and let 'er rip. Repeat except you turn the valve to rinse. Done. You'd be hard-pressed to even get the cartridge filter apart in that amount of time, let alone clean it.
Welcome to TFP!
That looks like a good list. I agree on the sand filter. You would also be fine with a smaller 2 speed pump, 1hp or 1-1/2hp. But, running your 2hp on low speed will be OK too, not too bad on your electric bill.
Hillbillyville! I love it!
I purchased the saltwater 8000 and it seems to be a really nice pool. Had it put up last fall so I havent had a chance to swim in it yet. I seen they released the lx version which I wished I had a chance to buy,but in hindsight I think those dark top rails are going to get really hot in the sun.
You can really do without the wall foam. It serves no practical purpose.
