Thread: New Pool Questions???
    TomGallopavo's Avatar
    Apr 2016
    Hillbillyville, MO
    160
    New here. We are planning on putting in this pool shortly from The Pool Factory but have not ordered anything yet:
    My Pool Package
    Edit
    24'x54" Saltwater LX Round Pool $2,007.00 1 $2,007.00
    Hayward Thru-Wall Skimmer & Return Fitting $0.00 1 $0.00
    24' Round Peel N' Stick Foam Pool Cove $89.00 1 $89.00
    24' Round Pool Wall Foam $69.95 1 $69.95
    AquaPro 200 SQ. FT. Cartridge Filter System 2-HP 2-Speed Pump 2 Year Warranty $549.00 1 $549.00
    Main Access Pro Series In-Pool Deck Ladder $44.99 1 $44.99
    24'x54" Round Uni-Bead Beach Haven Liner - 30 Gauge $275.00 1 $275.00
    Solaxx Saltron Retro Jet RJ Saltwater Chlorine Generator - 2 Year Warranty $429.00 1 $429.00
    Aqualuminator Above Ground Pool Light 98605000 $99.99 1 $99.99
    9" x 24" Ladder Mat $8.99 1 $8.99
    We live in the country on a farm so there are no neighbors or regulations etc. We would like your wisdom on the equipment above and The Pool Factory as well. I plan on installing myself: level ground, add layer of small crushed rock (1/4 in.), pool on pavers, add inch of pink foam. Please share your opinions and advice freely, I do not have feelings
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: New Pool Questions???
    Welcome!
    Do you get a lot of blown dust? A sand filter is the easiest to clean; flip the switch, turn the valve, flip the switch again and let 'er rip. Repeat except you turn the valve to rinse. Done. You'd be hard-pressed to even get the cartridge filter apart in that amount of time, let alone clean it.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Welcome to TFP!
    That looks like a good list. I agree on the sand filter. You would also be fine with a smaller 2 speed pump, 1hp or 1-1/2hp. But, running your 2hp on low speed will be OK too, not too bad on your electric bill.
    Hillbillyville! I love it!
    Apr 2016
    Kankakee Il
    39
    I purchased the saltwater 8000 and it seems to be a really nice pool. Had it put up last fall so I havent had a chance to swim in it yet. I seen they released the lx version which I wished I had a chance to buy,but in hindsight I think those dark top rails are going to get really hot in the sun.
    Casey's Avatar
    SW PA
    10,428
    You can really do without the wall foam. It serves no practical purpose.
