Thread: Replacing AG pool, how much should we save on installation?
    We are planning to replace an AG 21x41 Doughboy pool this spring/summer. The pool itself is 30 years old, liner was replaced about 15 years ago. At the time of liner replacement we added a deep end with a bottom drain. The steep walls of the deep end have a concrete/vermiculite type material on the walls. We will be replacing with the same size Doughboy pool with another expandable liner. As we shop, just wondering how much we should expect to save on installation. I would assume there would be minimal excavation and ground prep? The existing pool is still in place and was winterized and covered as always. Had a large slit in the liner last year that we repaired and babied thru the season, but know that the pool itself needs to be replaced instead of just a new liner. When we have decided on a dealer/installer we will follow their instructions, but will remove the existing pool ourselves, but don't want to tackle the new install. Thanks for any opinions and/or advice.
    21 x 41 above ground, vinyl, with deep end; 28,000 gallons; AquaView 24" sand filter, 2 hp pump,
    Casey's Avatar
    SW PA
    10,421
    Re: Replacing AG pool, how much should we save on installation?
    I'm sure you'll save on excavation but you're still going to pay for labor of the install. I'm unsure of how much that will be. Take pics if you can. We'd love to watch.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,383
    Call out 5 people and gets bids from them.........Ask lots of questions about how they will do the install to make it last a long time.......see who you click with the best. The main thing to ask WHO will be doing the work and how often they have done it.
    Good luck and make sure to take pics like Casey said!
    Kim
