Thread: Single suction pump question.
    JonathanD's Avatar
    May 2015
    Cape Coral, FL
    19
    I have had this pool over a year (older house, new to me) and have had it re plastered and re tiled...yet one thing still evades me.
    Single suction pool. I have my skimmer, two holes on the bottom, one with suction line and the other hole to the main drain. Am I (or can I) have a plate or anything that would help split the surface skimmer portion to also pull from the main drain?
    When I vacuum the pool I let the head sit over the top of the main drain for a bit, but I am doubting that does anything, and I can imagine all off the crud that builds up in there. I cant see how just being near the suction hole would provide enough lift to pull anything from the bottom of the pool to the top of the skimmer.
    Thank you for your help in advanced. I have searched but all answers seem to end up with people not knowing the main drain was connected to the pump, mine is not.
    13k Gallon IG plaster W/ aggregate finish, re plastered 7/17/15 . Offset rectangle.
    1.5hp 1 speed pump and roughly 100 sqft cartridge filter that will/ need to be replaced in near future.
    TF-100 test kit w/ speedstir.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    Re: Single suction pump question.
    You need a skimmer/main drain diverter. Here is a picture of the most common one. Most pool stores should have it.
    http://www.troublefreepool.com/image...erDiverter.jpg
    chiefwej
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    What happens if you hold your weir door shut? That should force the flow to come from the drain line.
    Here is a skimmer diverter. Find out which skimmer you have, sometimes it is on the underside of the lid.
    Pentair Bermuda Skimmer Float Valve Assembly 506160 | Pentair 506160
