Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: Hello West Texas!
    Dunitall's Avatar
    Mar 2016
    Monahans/Texas
    9
    Hello West Texas!
    Howdy, Cloudy and rainy today, Cold snap moving through. Im so Happy I found TFP. We had our Viking Pool installed in October 2008, We do enjoy it.This past year I broke rank and file and closed the pool completely down, due to our winter travels, Didn't want to worry w/ freezing anything. I uncovered the pool, Spring is here, The water was Kermit the Frog GREEN, maybe Hulk Green....Yikes.
    March the 28th,
    Mon. Day I get everthing running, drop in 1lb of Shock (Sodium Dichloro-S-Triazinetrione Hydrate) w/ pump 24/7
    Tue. Day 2 not a whole lot of difference, Pump 24/7. Start searching for help, found TFP.
    Wed. Day 3 not a whole lot of difference, drop in 1lb of Shock, add water. Pump 24/7. Order Taylor K-2006 w/ Amazon Prime.
    Thur. Day 4 Ooops forgot to turn off water, Pool full, 18" new water. Pump24/7 Flower beds Full, all is good. Water looks way better. Go to work
    come home, Taylor K-2006 arrived, go out side water WAY Better, vacuum all debris and sent to "waste". Break out the Taylor.
    Findings:
    FC 12ppm, CC 14ppm, pH 7.4, TA 160ppm, CH 290ppm, CYA 62ppm, Sat Index 0.0-0.1
    Okay TFP, Your the master, I'm the Grasshopper,
    April 1,
    Fri. Day 5, pump 24/7 rainy cold day.
    What do I need to do NOW!!!
    Thank You,
    West Texas, 2008 Viking fiberglass pool, 17,000 Gal. 1 1/2HP StaRite Dynapro pump-single speed @120 g.p.m., StaRite T-300 BP-2 Sand Filter@ 98 GPM Flo Rate @ 18 psi normal range. RainBow Lifeguard chlorine 3" tab chlorine feeder, Fiber Star pool lights and Freeze Sentry controller. Complete circulation: 2.3 hrs @ 100% or 2.9 hrs @ 80%...City Water.
    Jun 2014
    14,963
    Re: Hello West Texas
    Hey fellow Texan and Viking owner. Welcome! Glad you got the K-2006. Thank goodness. What to do now ..... SLAM my friend. Link is below in my sig. Read it carefully and don't skip a beat. Empty that tab feeder ASAP and do not put any more bags-o-shock in the pool. Those are driving up your CYA to a dangerous level. Use generic bleach from Wal-Mart (Great Value) or HEB (Bravo). Only Regular bleach - no scents or splashless junk. Use that bleach to maintain your FC at "24". Yep, an FC of 24 based on a CYA of 60. Do everything on that SLAM page and it will work for you. Let us know if you have any more questions.
    Dunitall's Avatar
    Mar 2016
    Monahans/Texas
    9
    Howdy Texas Splash, YeeeHawwww, Sounds like a Plan, Will go fetch the bleach today, and Thank You.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Welcome to TFP!
    Nice work so far! Ya'll have Amazon prime waayyy out yonder huh?
    Casey's Avatar
    SW PA
    10,421
    Welcome. Make sure you are MAINTAINING the M in SLAM!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,383
    Re: Hello West Texas!
    You are SO on the right track now! Test and bleach.............over and over until you see a jewel of a pool!
    Take a picture a day of your steps. That will let you see the daily changes that your eyes do not see. The color will start changing to blue then it will get lighter..........it is hard to notice without the pics.
    Kim
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome!
    Right down I20 from you here just outside Midland. Glad you joined the club.
    I missed the 2006 kit purchase, so good job on a proper kit. Doing a SLAM, you'll run low or out of FC testing reagent pretty quickly just FYI.
    Essential Links:
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Also stop all sources of stabilized chlorine, no more dichlor, trichlor or CYA stabilizer you are right at the top edge of what we consider maintainable for a manually chlorinated pool, use only bleach /liquid chlorine or invest in an SWG
    Dunitall's Avatar
    Mar 2016
    Monahans/Texas
    9
    Yep it do, wagon ruts fairly deep in some places all the way from here to there.
    Yr just down the road, good deal, no kidn about running out of regiment, done did, fired up the Amazon, should be here no later than Tues.
    Jul 2012
    Tallahassee, FL
    30,383
    LOVE your picture! Bet the lab loves the pool as much or more than you do! LOL
    Kim
    Dunitall's Avatar
    Mar 2016
    Monahans/Texas
    9
    Labs name is Trevor, He was my pard, Lost him in October last year, He was 15.
    50 bottles of bleach on the bench, 50 bottles of bleach 7 in, scrub it again, 43 bottles of bleach
    43 bottles of bleach on the bench, 43 bottles of bleach 7 in, scrub it again, 36 bottles of bleach
    36 bottles of bleach on the bench, 36 bottles of bleach 5 instead algae is dead, 31 bottles of bleach
    31 bottles of bleach on the bench, 31 bottles of bleach, add 5 barley alive, 26 bottles of bleach
    26 bottles of bleach on the bench, 26 bottles of bleach, add 4 algae no more, 22 bottles of bleach
    22 bottles of bleach on the bench, 22 bottles of bleach, add 3 and have no fear the water is clear.
    19 bottles of bleach on the bench, 19 bottles of bleach, add 3 FC’s in need, 16 bottles of bleach.
    16 bottles of bleach on the bench, 16 bottles of bleach, add 2 FC’s not thru, 14 bottles of bleach.
    14 bottles of bleach on the bench, 14 bottles of bleach, add 2 FC’s not thru scrub it again.
    12 bottles of bleach on the bench, 12 bottles of bleach, add 1 this has been FUN.
    11 bottles of bleach on the bench, 11 bottles of bleach, add 1 almost done.
    10 bottles of bleach on the bench, 10 bottles of bleach:
    OK team “What a Deal” Jeepers!!
    Sunday Eve @ 7PM
    FC 22, CC .5, pH 7.6, TA 150, CH 300,
    Monday Morn @ 5:30am
    FC 20, CC .5, pH7.5, TA 150, CH 250
    Last results to CYA was “100”, I ran out of regiment. Backups on its way.
    So do I keep up the FC @24 ???
    Jun 2014
    14,963
    Since you lost more than 2 ppm of FC overnight, I would continue to maintain. But two things that caught my eye on your last post:
    1 - Your CYA is higher now (100) than when we last spoke on 1 Apr (60). That would require a SLAM/shock level of 39. That additional FC may help you knockout the remaining algae.
    2 - When you get ready to do your next OCLT, make sure to not take the first reading until it's completely dark out. Sunday's was at 7:00PM, and unless you're in full shade, I still had sun on the water which means UV taking FC. So definitely make sure it's totally dark for both readings.
    Other than that, great job taking notes. I suspect you're getting much closer now. Oh, and until you pass the SLAM, no need to waste reagents on the other tests. Save those bottles.
    Dunitall's Avatar
    Mar 2016
    Monahans/Texas
    9
    Ok, got it. Will continue Slam.
    Jul 2012
    Tallahassee, FL
    30,383
    Quote Originally Posted by Dunitall View Post
    Hey everyone can I keep him????? I like him! Made me laugh out loud! THANKS!
    Sorry to hear doggy found his way to the bridge. There is nothing else like a dogs love
    Kim
    Casey's Avatar
    SW PA
    10,421
    So sorry for your loss. They are just like kids. I got 3 of'em.
    Dunitall's Avatar
    Mar 2016
    Monahans/Texas
    9
    YOU got that right, I miss him everyday. Glad you got a chuckle, gotta make it fun!!
    Whewwwwww!!! tough one, I look purity good in a Bikini, what color is it?
    Ok,
    We are There, Pool passed the OCLT, last nite / this morn. Water is AWESOME CLEAR, Replacements regiments expected today.
    Whats Next?
    Thank You
    Jun 2014
    14,963
    Now it's time to .........
    Enjoy and simply maintain your TFP recommended levels. Check/feed FC every day to keep her happy.
    Dunitall's Avatar
    Mar 2016
    Monahans/Texas
    9
    Is there a rule of thumb on how long the pump should run? Cycling hours? Daylight, Dark? Does the chemistry dictate any of this?
    Thank You
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Until you are done with the SLAM it's 24/7. Later, you can likely reduce it to an amount that will surprise you a great deal.
    Essential Links:
  20. Back To Top    #20
    Dunitall's Avatar
    Mar 2016
    Monahans/Texas
    9
    Finished the slam, yesterday. However the CYA is still 90?? CURRENTLY the water is CRYSTAL CLEAR, really impressive!
    Reading the blogs, looks like water replacement is the next step, so is it a full replacement or can it be done couple feet at a time?
    Chemistry:
    FC 7.5. CC .5 pH 7.5. TA 150. CH 250 CYA 90+
    Thank You
