Results 1 to 7 of 7
Thread: Hayward Navigator troubles
    pikeman's Avatar
    Jul 2008
    Pflugerville, Texas
    68
    I recently went back to a Navigator after a very expensive experience with the Barracuda MX5.
    I have plenty of slack suction line so it isn't restrained in any way. However, after about three hours it will be completely hung up, almost tied in knots.
    I understand how the steering mechanism works and if it weren't so recently bought, I'd think it was broken.
    What am I missing with this thing?
    Thanks!
    Pete
    20K IG, WetEdge technology lined pool, TF100 Test Kit, CircuPool RJ60+, StaRite pump, Hayward DE filter, Hayward Navigator pool vac. Zodiac MX8 vacuum thrown in garbage.
    Casey's Avatar
    SW PA
    10,457
    Re: Hayward Navigator troubles
    I'm not sure and hopefully someone will know.
    Feb 2015
    Chandler AZ
    938
    You mention you have "plenty of slack suction line". Is it possible you have too much slack? If you take out a section or two, will it still reach everywhere it needs to?
    Do you also have an in line leaf canister on the cleaner suction line? If so, what is its location?
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    pikeman's Avatar
    Jul 2008
    Pflugerville, Texas
    68
    I have had some improvement from removing one section of hose, adjusting the back flap to position 3 and throttling back on the skimmer a bit. But it is still getting twisted up.
    No leaf filter.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    And you are using only the sectional hoses it came with right? not a long hose attached to the other hoses?
    Try removing another and see what happens.
    Mine works very well.,,I only use enough hoses that it barely reaches to each end of the pool.
    Both Navigators I've had (one was for a gunite pool, the other for vinyl) might create one hose loop
    after going for several hours but never more than that.
    Dolphin E10 Cleaning Robot.
    Mar 2007
    Murrieta, CA
    215
    I know this is an old thread but I thought I'd respond in case anyone else has the same problem.
    I had this happen to me several times with my navigator. The root cause of the problem was in the "gearbox". This is an internal component that uses water flow to slowly turn the hose connection left and right to steer the Navigator.
    If something gets caught up in the gearbox, then the navigator will only turn in one direction. As a result, the hoses get all twisted up.
    You can replace the gearbox, or you can easily take it apart. Just pull out all of the plastic gears and clean them make sure there's no debris. Something as small as a tiny pebble or blade of grass can cause the gears to bind.
    One way to easily test the gearbox is to blow air into the hole where the water enters. You should hear the gears whir as you blow. If you can't get the gears to turn, then you'll need to take it apart.
    Finally, the other thing that contributes to this problem is the plastic screen along the back of the Navigator. This is the area where the gearbox pulls its water. If the screen is cracked or has holes in it, then debris can more easily enter the gearbox.
    Since I discovered this, twisted hoses are easy to fix, although it does take me 20 minutes or so to disassemble the entire unit and clean out the gearbox.
    ~13500 gallon gunite pool, Pentair Intelliflo 4x160, Pentair 520 SF cartridge filter, Pentair MasterTemp 400 NG heater
    Pentair Easytouch with IC40 SWCG, Hayward Navigator on dedicated suction line
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    Before taking the unit apart do a turn test first. The twisting of hose can be two things. The unit turning in one direction or the hoses were stored coiled up. If they have been coiled up lay them in the sun to see if they will straighten out. If the hoses have not been coiled the problem is either the gear box being jammed or one of the pods have come loose from the a-frame. Do this test. Hold the cleaner by the hose just above where the hose attaches to the cleaner. Hold it under the water and turn on the pump. If the gear box is jammed it will rotate in one direction only. Watch for a few minutes. Correct action would be that the cleaner turns right stops for a while and then turns left. 3-4 turns on average both right and left. If the unit is working properly and the hoses are still twisting up one of the side pods is loose causing the unit to track in one direction. Replace both pods and aframes.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
