Thread: Should I be testing for metals
    Jun 2015
    Burke VA
    53
    Hey guys, about to open my pool shortly here in Northern Virginia. I was curious if i should be testing for metals in the water after opening and balancing the chemicals, as far as i know i didn't have any issues with metals last summer (first year of pool). Also, any need to add any algecide or other chemicals to the water during opening. Last year all i used was CYA, bleach, baking soda, and sometimes borax. Thanks, and i look forward to being an active member on the forum this year again!
    Above Ground Kayak Pool 12 x 24. 10,000 gallons.
    Northern Virginia
    TF-100 Test Kit
    sta-rite 27002-0100S filter
    Sta-rite 1.5hp pump
    38,260
    Re: Should i be testing for metals
    If you have no reason to suspect metal, then no reason to test.
    There is never a need for algaecide. What you need to add to open depends on your test results and how the water looks.
    Jun 2014
    15,030
    You can always dust-off the old cobwebs by reviewing this page: Pool School - Opening Your Winterized Above Ground Pool.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Unless you're on a well or your municipal water supply has old rusty pipes, you probably don't have a metal problem.
    If your pool looks clear and suddenly turns clear green when you add bleach, you have metals. Otherwise, don't sweat it. You likely would have seen colored blotches on the pool surface and green-haired kids last year if you have metals.
